93 k1500 shifting probs and high idle
Discussion in 'Chevy Truck Forum' started by Natas 9000, Jun 30, 2010.
  1. Natas 9000
    Natas 9000 Full Member
    May 11, 2010
    17
    A/C Tech, CNG Tech,
    SLC, UT
    #1 Natas 9000, Jun 30, 2010
    K so I have a 93 Chevy Ext. Cab k1500 with a 5.7 TBI, Auto trans.
    I'm having issues with the motor idling pretty high, the trans jumps into gear with I shift into Drive, and I have to rev my truck up for it to shift up? Any ideas what to look at first:idea:. Thanks in advance for all your help:D.
    Just had a tune up plugs, wires, cap, rotor, and about a month ago a new ignition module (in distributor).
    Was driving just fine then lone and behold **** lol. So if anyone has any ideas, I've read alot of threads and post, sounds like people try alot of things to no avail so I figured I'll ask first. Thanks again everyone!
  2. bradrhale
    TPS would be the very first thing that i look at. all your symptoms including the late shifts points to exactly that. there is a TPS diagnostic chart located in The Reference Thread in the general truck section on how to test this with a halfway good multimeter. if this does turn out to be the problem, clean out the port that the TPS reads out of on the side of the TB as this can develop pretty heavy carbon deposits in there. do not spray the TPS or IAC as this can cause them to fail.
    TPS, throttle position sensor, should be loacted on the drivers side of TB
    IAC, idle air controlling sensor, should be located on the rear side of TB
    Case 7230 likes this.
  3. Natas 9000
    May 11, 2010
    17
    A/C Tech, CNG Tech,
    SLC, UT
    awesome thank you I will look into that.
  4. mudseeker
    581
    also look for a vac leak at the throttle body gasket. spray carb cleaner at the base of the throttle body, if it attempts to stall or does, then you found your problem.
  5. Natas 9000
    May 11, 2010
    17
    A/C Tech, CNG Tech,
    SLC, UT
    TPS was the problem thanks for your help. I did the carb cleaner first thinking that was the problem. But faulty TPS is to blame. Bought a new one and put it on runs great.
  6. crabtruck
    Good to hear you got it Natas.
    Thanks for the update, helps everyone.
  7. bradrhale
    good deal. did you clean the port for the TPS also?? alot of times, the buildup will contribute to the failure of the sensor. remember that an ounce of prevention is worth a pound of cure.
  8. Natas 9000
    May 11, 2010
    17
    A/C Tech, CNG Tech,
    SLC, UT
    yeah I did, took it off cleaned it. Thanks again for all the help
