94 46rh problems Please Help ASAP
Discussion in 'Dodge Truck Forum' started by chevyracer8262, Jun 3, 2009.
  1. chevyracer8262
    chevyracer8262 Senior Member
    Jul 23, 2008
    144
    Marine Designer/Engineer
    Mississippi
    Hi all I have a serious issue with a 94 1500 that we bought. When we got it the transmission was pouring fluid out the front seal so i removed the a518/46rh tranny ans replaced the pump and converter (before rebuilding) and all it had was forward gear. I've since rebuilt the entire unit and followed the instructions and specs from the ASTG overhaul manual. Well here's where I've run into my problem after reassebling the truck I put it on jack stands and have all the forward gears but no reverse. As long as it idles the rear tires will turn but as soon as you give it any throttle the tranny locks up like it has a drag racing transbrake in it. (Like reverse and a forward pack are engauging at the same time). Does anyone have any idea as to what can cause this, I've already removed the transfercase and od unit and and checked them out but i'm stumped as to what can cause this. Any Ideas or any help would be greatly appreciated cause between this thing and my wife driving me crazy about getting her truck fixed is driving me nutz.
    Oh yea I used a Transtar rebuild kit the had all new seals, bushings, borgwarner friction plates and band to rebuild thins thing. if any of that helps.
    MrMarty51 likes this.
  2. mudseeker
    585
    did you soak the clutches before you assembled the trans?
  3. chevyracer8262
    Jul 23, 2008
    144
    Mississippi
    yes I soaked the friction disks and bands for about 20-30 mins before starting reassembly, just like I do with any transmission I rebuild
  4. mudseeker
    585
    is it possible that you have a fluid pressure problem? maybe the valve body is damaged? does the band hold in reverse or first, i can't remember, not familiar with dodge.
  5. Dman1192
    Dman1192 New Member
    Jul 11, 2016
    I literally have this exact problem! Help! What fixed this?!? Truck is down right now and struggling!
  6. gmctrucks
    9,132
    4,877
    Hey guys what about viewing some videos on YouTube you might get lucky and find out what up.
  7. MrMarty51
    Pressure tests.
    Might be that O`riellys has a trans pressure test system that they will rent to You.
    Hook the gauges to the pressure ports and please report back.
    Sounds to Me though as there could possibly be two clutches engaging at the same time.
    If there is only one pressure gauge in the kit then, rent another kit from somewhere, or put together the hoses and gauges.
    I think that there are three pressure ports.
  8. Dman1192
    Dman1192 New Member
    Jul 11, 2016
    Ive had the trans appart and back together three times and swapped valve bodies. Still no luck and everything inside looks good even the master-tech i work with is confused!
  9. Dman1192
    Dman1192 New Member
    Jul 11, 2016
    I had hoped the original poster chevyracer8262 had an answer on they fixed it but i have no idea how else to contact them
  10. bigbear4l60
    bigbear4l60 Member
    Jan 18, 2012
    V.A
    reverse works off rear band
