94 Chevy 1500 Overheating
Discussion in 'Chevy Truck Forum' started by j clack, Jan 4, 2010.
  1. j clack
    j clack New Member
    Jan 4, 2010
    Self Employed
    Georgia
    I changed the water pump, thermostat and took the top hose off..nothing comes out. The bottom hose was cold and top was hot. Shouldn't the water come through the bottom? Which direction should the water flow, from the top hose into the radiator? Or from the radiator into the top hose?
    Any advice?
    JClack
  2. 88fivespd
    88fivespd Full Member
    Jan 16, 2008
    318
    180
    You probably don't have all the air out of the engine block. Disconnect one of the heater hoses at the engine and leave it off while you pour coolant into the radiator. The coolant should come pouring out of the fitting you took the heater hose loose from. Yes, the coolant flows top to bottom through the radiator.
  3. Faxcion
    Faxcion Senior Member
    Jun 18, 2009
    65
    Outdoor Power Equipment Specialist at Lowe's
    Calico Rock Ar.
    Changed the oil lately?
  4. gmctrucks
    7,995
    3,512
    Welcome to the forum and howdy from TEXAS. Once the stat opens the water should come out of the top hose and go into the radiator. Did you place the stat back-wards did the give you the right pump? Maybe the stat is messed up it can happen even if it's new. When I fill my radiator on my 1993 5.7 truck I leave the cap off till the stat opens then I top it off I have never had a problem with air pockets now I have a high flow pump boy does it push out the water im very happy with it.
  5. bradrhale
    which direction pump did you put in?? do you have good flow through the radiator?? the water should go through the lower radiator hose into the pump and come back through the upper hose. remember that heat rises so the upper should be hotter first. could be air in the system as mentioned above or a tstat tht is faulty or installed backwards. if nothing comes out of the hose, i would believe a problem at the t stat unless the system is extremely low on coolant.
