94 gmc 4x4 half ton rear end noise
Discussion in 'GMC Truck Forum' started by brownfirehawk, Jan 29, 2011.
  1. brownfirehawk
    brownfirehawk Member
    Jan 29, 2011
    Ok my truck is making a tinny nocking noise on decelration and under light throttle. It also seems to coincide with the trans downshifting so it does it at about 55-60,35-40,25-30. i have replaced the rear u joint and changed the rear end lube and added the friction modifiers as it is a limited slip. Any ideas
  2. gpmorgan
    gpmorgan Auto Banned
    Nov 21, 2009
    2,687
    288
    83
    forklifts and equip tech
    Tupelo Ms.
    Sounds like you might have a cracked flywheel(flexplate).
    Check all good sound travels in the drive train could be a flex plate like JP said.
  4. brownfirehawk
    Jan 29, 2011
    Yea well i popped the diff cover and to my cringing eyes the pinion gear is missin a few teeth and the ring gear has a few chipped. Its a ******* trying to find a 3:73 rear end in lower michigan....
