94 pick-up
Discussion in 'Toyota Truck Forum' started by ranger2001, Nov 27, 2009.
  1. ranger2001
    ranger2001 New Member
    Nov 27, 2009
    Just got a 94 pu, 4cyc, man., 2wd. No emblems on it anywhere so I'm guessing it's a base model. The fuel pump doesn't run when you first turn on the key. Is there a fuel cut-off/inertia switch somewhere or something else to look for before pulling the pump? Also, what size motor is it. Thanks
  2. davbell22602
    A 94 toyota Pickup What modelis is it?
  3. ranger2001
    Nov 27, 2009
    I don't know. Just a 1994 Toyota pick-up.
  4. davbell22602
    got pics of this truck to post. what is this a v6 or v8? Got vin to post so somebody can look it up by the vin for you.
  5. ranger2001
    Nov 27, 2009
    2.4, 4 cylinder. I figured out the motor size.
  6. davbell22602
    So what saying is the truck won't start and you don't hear the fuel pump come on when turning the key forward right? If so check for a fuel pump relay first.
  7. ranger2001
    Nov 27, 2009
    OK I'll try that first. Thanks
