95 gmc turns over but wont start
Discussion in 'GMC Truck Forum' started by asifford5, May 10, 2011.
  1. asifford5
    asifford5 Senior Member
    Dec 2, 2010
    67
    My friend got into his truck (95 gmc k1500 z71 with 350 v8) this morning and turned the key and it just clicked. Jump started and nothing. Came back after school and jump stared it with better cables and it started right up. Let it run a while and disconnected the cable. Tried to start again. It turned over but wont start. Jump started it again and it started. Disconnected the battery to test alternator and it died. Tried to jump it again and wouldn’t even start with cables. Put a new battery in it and still cant get it to start. Poured gas into throttle body and still wouldn’t start. Checked for spark and no spark. We have power into ignition coil but not out. Replaced it and still won’t start. so we gave up for thee night. Any suggestions will be greatly appreciated. thanks.:help:
  2. kronhenry
    kronhenry Senior Member
    Apr 21, 2011
    211
    15
    check the icm in the distributor its what sends signal to the coil to fire and injectors to pulse. they are pretty cheap to replace
  3. asifford5
    Dec 2, 2010
    67
    What is the icm? I can't find anything on it in my Haynes guide
  4. kronhenry
    Apr 21, 2011
    211
    15
    this is the icm
    another thing check all the grounds and make sure they are all clean
  5. asifford5
    Dec 2, 2010
    67
    thanks for the help. we replaced the icm and it fired right up
  6. kronhenry
    Apr 21, 2011
    211
    15
    no problem nice to hear it fixed your problem
