96 gmc jimmy won't start
Discussion in 'Chevy Truck Forum' started by Tooch75, Nov 1, 2010.
  1. Tooch75
    Tooch75 Member
    Nov 1, 2010
    Hi all, new to this message board and trying to find an answer to my major problem. Here it goes.
    I was driven my 1996 gmc jimmy w/ a 4.3 vortec engine , down the road and the truck just died on me. The truck cranks over but does not start. When cranking over, ever 5 seconds or so, the engine stops cranking like its becoming hydro locked. Checked the fuel pressure, 62 lbs. (key on), 58 lbs (cranking), seems o.k. Check for spark at coil and plugs, have spark. Changed crank shaft sensor. Truck will not fire with starting fluild with fuel pump on or off. Pulled top of intake off, spider tubes look o.k.,not burnt or broken. Have alittle gas puddling in the # 5 & 6 cylinder intakes. Seems like fuel is coming from vent tubes that are in front fuel metering body. I'm running out of ideas. Please any help will be appreciated
    22,406
    13,171
    Sounds like a timing issue. Check see.
  3. Tooch75
    Tooch75 Member
    Nov 1, 2010
    With #1 cylinder @ tdc, pulled dist cap off and the rotor is @ #1 . Would the timing be able to go out as i was driving ?
  4. 92chevywt
    92chevywt Full Member
    Oct 31, 2010
    52
    kalamazoo,MI
    yes the timing would normally jump while ur driving but besides that when u checked for spark what color was the spark because you could have spark just not hot enough spark to ignite all the fuel, just a guess
  5. Tooch75
    Tooch75 Member
    Nov 1, 2010
    I checked the spark w/ a spark plug tester w/ the mini light bulb iside of it. I've been talking to some people and they are telling me to change out the fuel injector system. Not 100% sure that's the problem, costly part on a guess. Is there a sure way to test the injectors w/ the spider tubes ? BOY, I HATE TRYING TO SAVE MONEY!!!!!
  6. 92chevywt
    Oct 31, 2010
    52
    kalamazoo,MI
    well i say no on the fuel injection as it didnt start with the starting fluid. Question is did it sputter or attempt to start when u sprayed the starting fluid???
  7. Tooch75
    Tooch75 Member
    Nov 1, 2010
    No, just popped a few times out of the butterfly. Changed the coil today with no luck. Would the pick-up coil give you a weak spark?
    22,406
    13,171
    Could ,but usually they go their out. And most time go out when you shut engine off . Try and see . When i have to change coil i go ahed change pick up.
  9. Tooch75
    Tooch75 Member
    Nov 1, 2010
    O.K. Here's a ?. What would cause a weak spark? My next step is poss buying a new computer, but I hate to spend the $130 if it's not the problem. Did I mention I hate newer vehicles
  10. chevychase
    22,406
    13,171
    Did you run a scan on it ?? Get a cel . Just wondering.
