96 sierra-cruise control not engaging
Discussion in 'GMC Truck Forum' started by svracing, Jan 26, 2009.
  1. svracing
    svracing Member
    Jan 26, 2009
    Hello! I just bought a 1996 gmc sierra. In pretty good condition. I was on the freeway trying to get the cruise control to work. I tried every combination, but it would not engage. I just checked the user manual for the correct procedure. I am going to try that out tonight.
    If, for some reason, the cruise control is not working. What are the common issues? Where should I start diagnosing the problem? Is there a fuse that I can check?
    12,320
    7,420
    welcome to the forum,
    Yes there is a fuse for it
  3. silverhairdeere
    silverhairdeere Senior Member
    Feb 15, 2008
    1,831
    33
    disabled
    land between the lakes tn
    switch on column, servo , ecm ,vacuum hoses , control module on the right side of brake pedal switch . vehicle speed sensor sensor ,on some of these you can test with a multi-meter .
    shd
  4. svracing
    svracing Member
    Jan 26, 2009
    Looks like a manual is in order. Thanks for the input.
  5. silverhairdeere
    Feb 15, 2008
    1,831
    33
    disabled
    on my 1996 lumina it was the ecm . yep i didn't know it controled it too .
    shd
