97 Chev 1500 Express C.E.L. P0340 CMP problem
Discussion in 'Chevy Truck Forum' started by FAATmofo, Sep 11, 2008.
  1. FAATmofo
    FAATmofo New Member
    Sep 11, 2008
    I have a 1997 5.7L 1500 van I am trying to fix. I had originally pulled 4 codes out of this truck and 3 of them were O2 codes the last one was a P0340 Camshaft Position Sensor Problem. Replaced the O2 sensors and the CMP sensor, and I still had a p0340 code in the computer. When I looked at the data on my scan tool I found that the PCM was retarding the timing -45 degrees. I checked the installation of the sensor and the teeth on the distributor gear. All were fine so I got a new sensor just in case and then I checked voltage at the three wires to the CMP connector. All checked out fine and I was getting a signal. Still it was retarding timing. So I moved the distributor while the car was running and it didn't budge. Please help me out here...I don't know where to go with this.
    Does anyone have the wire color, pin number and connector number of the Camshaft Position Sensor at the PCM?
    Or any other ideas here?!!
  2. mudseeker
    8,754
    580
  3. Case 7230
    A friend of mine had the same type of trouble with a small Japanese car. His scan tool kept telling him a defective cam position sensor, even when he fitted a new one. The problem turned out to be a worn timing chain. Just a thought. Good luck.
  4. FAATmofo
    FAATmofo New Member
    Sep 11, 2008
    I can understand the timing chain issue but even when I turn the distributor manually while the engine is running, I get no change in timing.
  5. mudseeker
    8,754
    580
    the timing is controlled by the computer, turning the dizzy will not effect it.
