'97 GMC 5.7 Sierra Z71 needs OE Plugs
Discussion in 'GMC Truck Forum' started by OssipeeSteve, Jun 17, 2008.
  1. OssipeeSteve
    OssipeeSteve Senior Member
    Mar 6, 2008
    238
    44
    Retired Tel.Tech among others
    Plymouth, MA
    I cheaped on the tune-up 40,000 miles ago not going with OE plugs and I think I'm paying the price in mileage. I used to get almost 20 mpg highway in the warmer weather (pre 10% corn in the gas, ethynol) and now its 16 mpg. Anybody got the word on the best plug for the truck with 137K miles?
    Thanks, Steve
  2. mudseeker
    581
    AC Delco..........
  3. 03chevy
    03chevy Senior Member
    Dec 28, 2006
    1,244
    50
    factory warehouseman
    jax,fl
    i have had bad luck when not useing oem parts... i had a 87 z24 and used wells every three months i had to replace something. then i went to the dealer and got ac delco and no problems. so if you have a gm use only ac delco parts less headaches in the long run
  4. OssipeeSteve
    Mar 6, 2008
    238
    44
    Plymouth, MA
    Thank you, Gentlemen. I'll post my highway MPG as soon as I have returned from my next trip with OE plugs.
    Steve
  5. jimbo543
    jimbo543 Senior Member
    Sep 5, 2007
    208
    14
    GM/MOPAR certified tech
    MN
    replace the t-stat, mileage will improve
  6. z07
    z07 Senior Member
    Feb 12, 2008
    391
    I've got dyno numbers and 1/4 mile ET's that show no correlation between expensive plugs and performance. I do, however, run NGK Iridium plugs in our Corvettes simply because they are a pain to change and those last longer than others and they don't have the problem with the pucks falling off like the platinum plugs did. With all that said, I'd use the OE spec AC Delcos without hesitation in any application where they can be changed without too much effort.
  7. ukrkoz
    ukrkoz Senior Member
    Feb 8, 2008
    174
    12
    HALO plugs. OEM specific, only plug on the market proven by government and independent reseraches to improve power and mpg. don't expect miracles, acetone is for that, but it gives anywhere between 1.4 to 3.2% improvement. i have all cars i can on them and am very happy. no, i have no $$ interest in those.
  8. leolkfrm
    12,609
    7,667
    sounds like the o2 sensor might be getting weak. Check the voltage reading with a good scan tool and see if it may be in the lower end of range.
  9. OssipeeSteve
    Mar 6, 2008
    238
    44
    Plymouth, MA
    Thanks, guys. Did pick up the OE Delco platinums. When I'm up my bud's place I'll put the scanner on for the O2.
    Priciate it,
    Steve
  10. Diddly
    Diddly Member
    Jun 27, 2008
    retired
    Suthn half of Nortern Nevada
    Ustta do dyno tune-up in Inglewood, CA. My take on spark plugs is that the better Spark plug likely has more to do with matching the heat range with your driving habits. All city= hotter heat range all open road cooler plugs. Far as gas mileage your corn alcohol has less energy per gal= less miles per gallon. Supposed to drink corn licker not put it in your gas tank...........
    Diddly
