ABS & Brake Light Comes On Intermittently
Discussion in 'Dodge Truck Forum' started by florida9, Apr 28, 2010.
  1. florida9
    florida9 New Member
    Apr 28, 2010
    Lake Worth, FL
    #1 florida9, Apr 28, 2010
    The ABS & Brake Light come on sometimes when i start the truck if i turn it off and back on a few times it will go away my speedometer is working but its off by 5mph i think its because my tires are a little bigger then normal (265) i replaced the rear sensor on top of the diff but the light still comes on sometimes when i start the truck i also checked the fluids & plugged a code reader in it did not find any codes. i have a 1998 Dodge RAM 1500 Pickup 5.9L V8 Magnum it has 156,294 Miles any suggestions would be great
  2. Towtruck
    Towtruck Senior Member
    Aug 20, 2009
    161
    Tool Repair Technician, honda small engine certifi
    Ft.liqourdale, FL.
    it could be a bed sensor on the master cylinder. or a bad abs wheel sensor
  3. Case 7230
    Check the brake fluid level and the wiring connections at the brake master cly. as Towtruck says.
    Has your truck got full ABS or the rear wheel anti-lock?
  4. leolkfrm
    12,436
    7,515
    plug a scanner into it and stop the guess work!
  5. florida9
    florida9 New Member
    Apr 28, 2010
    Lake Worth, FL
    it has 4 wheel abs and for the scanner i plugged a normal scanner into it and it did not find any codes i tryed to find a abs code reader and no one has one i can use they sell them for 200 dollars so that's not really a option o and the brake fluid is full
  6. leolkfrm
    12,436
    7,515
    a good scanner will give you the readings for each sensor, compare them to spec!
  7. bradrhale
    never heard of an ABS code scanner. never heard of any scanner for that matter that costs 200 bucks. i have however seen code readers that costs 200. the scanner that leo is refering to costs alot more than that because it is capable of alot more. it reads in real time each sensor to display a numerical value that can be interpreted. with this info, you can then decide what exactly is failing.
  8. Case 7230
    Check that the front hub sensors are clean, check the wires to them for cracking, check any plug connectors to them for corrosion/loose and check that your front wheel bearings have no play.
  9. 454 BOY
    454 BOY Senior Member
    May 18, 2009
    118
    Owner/Operator lawn care, landscape, and snow remo
    Indianapolis, Indiana
    Mine did that, it was because I have 285's on and they were like rubbing the sensor (wheel speed), I end up haveing to unplug the ABS until I go down to smaller tires
