Adjust clutch?
Discussion in 'Chevy Truck Forum' started by dolphinsfan1966, Mar 29, 2009.
  1. bradrhale
    yungin?? anything like an onion?? have never needed to adjust a clutch on something like what he is talking about. nor would i own a cutlass.
    only reason i adjust the clutch in the big truck is with normal wear over the process of 500,000 miles, one would expect some play there. i have to lockup that tool as the driver would be underneath there torqueing her down at the drop of a hat. fixing to break his hand off if he does one more thing to that truck.
    12,309
    7,414
    and on yours you adjust inside the housing not the linkage or it becomes a mess, to many people adjust the linkages instead of the clutch
  3. bradrhale
    cant adjust the linkage on mine. ours is in the clutch pack like you mentioned.
  4. leolkfrm
    12,309
    7,414
    I drove an 01 sterling rented from ryder, if the mechanic was lazy he would mess with the linkage cause he was too lazy to do it right
  5. bradrhale
    ill never work on another sterling. my last encounter with one left a bad taste in my mouth. mounted both fuel filters on top of one another in the frame rail. i was about ready to torch it just on a filter change. sad aint it??
  6. leolkfrm
    12,309
    7,414
    well you have to remember it is a FORD product
  7. NonGoggleGuy
    NonGoggleGuy Full Member
    Mar 2, 2009
    273
    Technician
    New York State
    Well, all joking aside, you're NOT supposed to suck on parts.
  8. NonGoggleGuy
    Mar 2, 2009
    273
    Technician
    New York State
    Sorry, I couldn't resist.
  9. leolkfrm
    12,309
    7,414
    he did not say what his bad encounter was:rofl:
  10. bradrhale
    wasnt sucking. to gain access to the top filter, you must remove the lower filter and then remove the top filter and snake it around the mount for the lower filter. when you do fuel filter changes on big trucks, you must fill them with diesel. when i tried to snake it back up, the stupid thing fell to one side and poured fuel all over me. my mouth was open and everything as one might say. it was open because i was cussing.
