Automatic transmission stuck in 3rd
Discussion in 'Chevy Truck Forum' started by toddatta, Jun 25, 2011.
  1. toddatta
    toddatta New Member
    Jun 25, 2011
    I have a 93 chevy k1500. Tranny does not shift unless you shift into low then it will start in 1st. Put it in drive and it seems to be in 3rd.
  2. kronhenry
    kronhenry Senior Member
    Apr 21, 2011
    211
    15
    sounds like a stuck solenoid in the valvebody throw some z max or lucas tranny treatment in it drive it for a little while and the try the drive gear again if not could be the vss is getting an inaccurate reading and not telling it to shift right
  3. NSguy
    NSguy Senior Member
    Jul 23, 2010
    242
    I haven't had much luck with running Lucas in the transmission... Try Trans-Medic. It's thin, isn't as viscous as Lucas and works its way into the small stuff easier.
    I'm thinking it's something to do with the VSS. 1993 was the transition year from the 700r4 to the electronic 4L60E transmission. Which one do you have?
  4. toddatta
    toddatta New Member
    Jun 25, 2011
    Hey thanks for the info. Not sure if ive ever heard of zmax. But have heard of lucas and used it in the engine. Could you please tell me what the VSS means and where it is located
  5. toddatta
    toddatta New Member
    Jun 25, 2011
    Okay...I will try the trans medic first. But how do you know which tranny it is...meaning 700r4 or 4l60e. And also this may sound dumb , but what is the vss
  6. Case 7230
    VSS is Vehicle Speed Sensor. It should be on the transfer case tailshaft. It will only matter if you have a 4L60E trans. Look in your glovebox for the transmission code to identify what trans you have.
