Backup light problem?
Discussion in 'GMC Truck Forum' started by sir bama, Apr 24, 2010.
  1. sir bama
    sir bama Member
    Apr 22, 2010
    My Right backup light wont work i have tred replaceing the bulb to no effect.All other lights work fine
  2. davbell22602
    Check your bulb socket and make sure you bought the right bulbs.
  3. dixie2009
    dixie2009 Senior Member
    Apr 17, 2010
    121
    22
    On my 98 GMC 1500, I have had to replace the strip that the bulb inserts into. Its got all three bulbs in that strip. You might try that. Just get a test light & check all the sockets to see if they are all hot except the back up. If its dead & the others are hot, test the wire to that socket. Hopefully that will help.
    If that wire is dead too, you might try to check the back up switch. I have never had to change that. Maybe someone else can help you locate & check it. I know its a switch possibly in the sterring colum. When you shift to reverse it activates the switch to make the light come on. It could be on the transmission???
  4. Ihatemyford
    Ihatemyford Senior Member
    Dec 8, 2009
    195
    I had the same problem with my brake lights, and my brother had it with his rear lights when they were supposed to be on... turns out he had a wire that was broken, and i had a loose wire. Otherwise, i would suggest buying a new circuit board
  5. kirbymurphy
    kirbymurphy Senior Member
    Dec 26, 2009
    76
    Make sure you have a good ground to the lamp base or board.
  6. jeffs83chevy
    jeffs83chevy New Member
    Apr 19, 2010
    thats what mine was doing...try to replace the lead wires going to the bulb housing
  7. itsjared
    itsjared Full Member
    Dec 18, 2009
    I replaced the circuit board three times before I though about the insert for a trailer hitch wiring. Turns out my fault was there... mostly. Now my left brake light is out but not the tail lights... I don't understand how this works after two years...
