Backup light switch location
Discussion in 'GMC Truck Forum' started by theoldman, Oct 12, 2006.
  1. theoldman
    theoldman New Member
    Oct 12, 2006
    Hello,
    I have a 95 1/2 ton 305 v8 5 speed. I believe the backup light switch is bad. Will I find it bolted to the transmission, or should I look elsewhere? Thanks in advance,
    theoldman
  2. Ford4x4Chik27
    Ford4x4Chik27 Senior Member
    Sep 19, 2004
    1,725
    It is located at the base of your shifter on the left hand side. Shouldn't be too hard to fix if you go in through the top :D
  3. bobcat5544
    bobcat5544 Full Member
    Sep 25, 2006
    Incorrect, the truck is a 95 1/2 ton 305 v8 5 speed which is a manual transmission. the back up light switch is located on the transmission. there are only two sensors on the transmission the sensor to the rear of the transmission is the speed sensor, and the other is the back up light switch, which is on the drivers side of the transmission, about mid way it will have two wires one is pink and the other light green
  4. Ford4x4Chik27
    Sep 19, 2004
    1,725
    According to the OEM specs it is on the left hand (which would be the driver's) side of the MANUAL SHIFTER on the transmission.
  5. NRNewsome
    NRNewsome New Member
    Jul 21, 2011
    ?I have a 93 GMC sierra 1/2 ton 4x4, 5.7L with an auto. trans. Is the back up switch located on the trans. somewhere? I jacked the truck up and searched all around the transmission with my hand and I couldnt find it anywhere. Any suggestions?
