Blinking 4 wheel drive light
Discussion in 'GMC Truck Forum' started by haulincats, Aug 29, 2009.
  1. haulincats
    haulincats Member
    Aug 29, 2009
    I have a 96 GMC 1500 Sierra 4x 4. It has the push button
    4 wheel drive buttons on the dash. Today I put it
    4 wheel drive (high or low) and the light in the switch
    just blinks. Where do I start looking??
    Thanks,
    Vance
  2. mudseeker
    581
    it's blinking because you hit 4low while in gear. put in nuetral if you want it in 4low, otherwise push the 2hi button and be on your worry free way.
  3. hotrodpc
    hotrodpc Full Member
    Jul 29, 2008
    7,277
    110
    Moore, OK
    Yep, Its waiting for you to stop the vehicle, go into Neutral then once its engaged, it will stop blinking, stay solid lit, to tell you its engaged and you can now go into gear and move. IF you are doing all that right and it continues to blink, then you likely have a defective engagement solenoid and it is not going to engage.
  4. haulincats
    haulincats Member
    Aug 29, 2009
    There is definately something wrong, it blinks when I try and
    shift from 2 high to 4 high. (4 high blinks)
    I have no idea where to start checking?
    Thanks,
    Vance
  5. hotrodpc
    Jul 29, 2008
    7,277
    110
    Moore, OK
    That is normal for it to blink, then should go solid after a few seconds telling you that 4high has engaged. IF its not doing that, then I would first suspect the solenoid on the transfer case.
