Changed Shocks & Now Front End Uneven?
Discussion in 'Chevy Truck Forum' started by OffRoadKid, Apr 14, 2012.
  1. OffRoadKid
    OffRoadKid Full Member
    Apr 3, 2012
    11
    I just changed all 4 shocks to Rancho because the originals were leaking etc. Now the driver side sits an inch higher than the passender side in the front. You can visibly tell by looking at the wheel wells that the driver side is higher. When I put the new front shocks on I did have to raise the control arms a little so that the bolt holes lined up with the new shocks...but if i completely completed extended out the new shocks when i put them on, then both sides "shouldve" been evenly aligned. I'm wondering if it's possible I didnt fully extended out the passender side shock? Has this happened to anyone before? Any ideas / suggestions would be a huge help. 1st time i ever replaced shocks. Thanks all
    What truck are we talking about? Over the years things get worn/weak. Take a look at sway bar bushings.
    Might tweak the torsion bars a little .If it is a 4x4. Might be the back springs making it lean weak .
    That is my take on it ..maybe others will chime in.
  3. OffRoadKid
    Apr 3, 2012
    11
    Chevy Silverado 1500 4wd. Before I changed the shocks the front end was totally even though. That's why I can't figure out why the driver side is now an inch higher after I put new shocks on. The only reason I changed the shocks is because the original's were starting to leak.
  4. onthethreshold
    onthethreshold Senior Member
    Dec 6, 2010
    410
    34
    Cuyahoga Falls Oh
    Have you driven the truck ? Perhaps when you messed with the control arm something didn't resituate properly . I wouldn't think the shock itself determines ride height . Is it possible you have mismatched shocks or a bad one ?
  5. dirtrider73068
    6,443
    3,854
    Shock doesn't deal with ride height, it dampens the ride hence shock, springs, tires, lift deal with ride height.
  6. greencamaro1981
    greencamaro1981 Full Member
    Feb 5, 2011
    410
    47
    detention officer
    bozeman mt
    ive run into same thing with ranchos the one shock i had was actually too short on the short side do you have down travel? like its bottoming out on the shock
  7. UncleBigBad1968
    UncleBigBad1968 Senior Member
    Dec 30, 2011
    249
    ne ok
    If it was fine before, then it has to be the shock itself not upholding its pressure.
  8. OffRoadKid
    Apr 3, 2012
    11
    Thanks guys for all the input. At this point I'm pretty sure It's a defective shock. I'm going to have Advance Auto order me a new one and I'll see what happens after I get it put on.
  9. Boudin
    602
    Shocks do not determine ride height. You can't change shocks and get a suspension lift, so to speak. Like it has been said....they simply cushion the suspension travel as it rides down the road. I have Rancho RS5000 shocks all around on my 84 C20 and have had great luck with them.
    Having said that.....is it possible that you have an incorrect or mismatched shock on the front that is bottoming out and not allowing the suspension to sit in a static position?
  10. OffRoadKid
    Apr 3, 2012
    11
    Well I changed the passenger side shock & same issue...wheel well sits an inch lower to the tire than the driver side. So shocks arent the issue. Is there anyway I thru the torsion bar settings out of wack when ******* the truck up etc? Should I just adjust the passenger side torsion bar an inch up? What other factors could cause this? I'm wondering if I should just take it into a shop and have them put it on a machine.
