Charging problem
Discussion in 'Chevy Truck Forum' started by Thedriller, Jul 14, 2012.
  1. Thedriller
    Thedriller New Member
    Jul 14, 2012
    Sparks,nv
    I have a 97 chevy 1500 with the 5.7 vortec. I have replaced both the altenator and battery and still will not charge. I have replaced both positive and negative cables and still does not charge. Is there something I am missing, any info would be great.
  2. BernieB
    BernieB Full Member
    Jul 11, 2009
    3,880
    37
    Replace the bulb in the idiot light. Seriously.
    22,287
    12,946
    22,287
    12,946
    Could be this or the gauge ..anything that would break the charging circuit
  5. Oldmech
    Oldmech Full Member
    Jan 12, 2010
    1,763
    214
    Iowa
    Umm... i know this may sound silly.. but I have found that the main connector for the gauge cluster likes to corrode.. Often whacking the dash will suddenly make the gauge start working again!!
    To see if your Alternator IS charging you can use a metallic object... lets say a 9/16 wrench.. hold one end to the bearing hub on the back of the alternator. if the alt IS working the hub will be magnetized and the wrench will stick to it like its glued. if it is NOT charging there will be no magnetism at that location. Its usually the first thing i do on a charging problem to see where i should start checking for a problem. :)
  6. leolkfrm
    12,609
    7,667
    is the no charge at the guage only or have you confirmed it at the alt?
  7. Boudin
    602
    Ditto....what have you done to determine it isn't charging? It sounds like to me that you might just be basing the non-charging situation on a gauge. You need to actually get a voltmeter out and check the voltage at the output of the alternator as well as the voltage at the battery.
