codes
Discussion in 'Chevy Truck Forum' started by david 87, Apr 5, 2008.
  1. david 87
    david 87 Full Member
    Mar 29, 2008
    11
    machinest
    Missouri
    what is code 32 on a 87 chevy truck 5.7 , how do i fix this
  2. Chevy_Finatic79
    Chevy_Finatic79 Senior Member
    Mar 30, 2008
    494
    38
    Self Employed Mechanic
    Lincoln NE
    code 32 is a EGR Loop Error. the books says this happens when is "sees" improper vacuum. so I would say you have a stuck EGR vavle or a vacuum leak or both but start there
  3. crabtruck
    Was this one with the solenoid for the EGR ? Egr may be only dirty and need to be cleaned. If you do have to replace it be careful of the differing types that look similar. I would think about using the dealership to avoid the wrong size orifice problems that seem to crop up from national chain stores.
    ikos10 likes this.
  4. junior3382
    junior3382 Senior Member
    3,171
    89
    If it is infact a vacuum problem, I would also look at the little hose that runs into it. Being small, it can also be very brittle. Happens with age. If there is a small crack in the line, then a small leak could lead to it reading an inpropper vacuum.
    ikos10 likes this.
  5. david 87
    Mar 29, 2008
    11
    machinest
    Missouri
    i found a small screw in the hose (dont know how that got there) bot it still has a code 32 after about 20 milles on the highway
  6. 87c10slammer
    87c10slammer Senior Member
    Mar 20, 2008
    3,221
    49
    levittown pa
    did you reset the computer. just pull the negitive cable off for a min.
    ikos10 likes this.
  7. david 87
    Mar 29, 2008
    11
    machinest
    Missouri
    yes did not help , it is also surging while i am coasting with the gas at about 15% down , like not enough gas getting to the TBI
  8. Chevy_Finatic79
    Mar 30, 2008
    494
    38
    Lincoln NE
    so did you look at your EGR valve yet? it only has 2 bolts and very easy to take off and if your careful you can re-use the gasket. Try cleaning the EGR valve like Cabtruck said.
    have you changed your fuel filter lately? cheap part huge performace monkey wrench when it starts to go
  9. jimbo543
    jimbo543 Senior Member
    Sep 5, 2007
    208
    14
    GM/MOPAR certified tech
    MN
    the surge is probably a b/o egr valve, a weak spring in the valve causes it to open too much at low speeds/low throttle. was screw in that hose?
  10. david 87
    Mar 29, 2008
    11
    machinest
    Missouri
    yes it was a small allen head screw
