cruise control '99 Tahoe
Discussion in 'GMC Truck Forum' started by mj6971, Oct 29, 2009.
  1. mj6971
    mj6971 Full Member
    May 7, 2008
    Have a 99 chevy tahoe LT cruise control not working fuse is good,there is no vacume hoses on cruise control unit. What is the problem?
  2. silverhairdeere
    silverhairdeere Senior Member
    Feb 15, 2008
    1,831
    33
    it could be anything from the cruise control module , the multi position swith on colum to the brake switch or even the ecm , with out further testing with test light and a muli-meter it's a **** shoot . you could try scanning for codes also. post back and let us know what you foumd out .
    shd
  3. crabtruck
    Like shd said, way too many possibilities with that little info.
    Can start with some basics though: is cable hooked tight from CC mod to eng?
    Is wire connector clean and tight at CC mod ?
    Are switch connections tight at brake (and clutch if man) ?
    If you have one of the radios with the speed effected volumes: work ok ?
    That's a shared signal wire from ECM to CC and radio.
    Does everything else on truck work right ? speedo, brake lites etc.
    Do try to get codes pulled - could be a huge help.
    Drawing just for reference:
  4. mj6971
    mj6971 Full Member
    May 7, 2008
    All the other things i checked.i do need to run the codes, the engine check light is on but went i had it turned off and the cruise still do not work.And I did in a cd player and the cigar light does blow the fuse for the lighter.
  5. OssipeeSteve
    OssipeeSteve Senior Member
    Mar 6, 2008
    238
    44
    Try changing out the brake switch. It cost $10 and be sure to pick up a new switch retainer clip before you start. Its cheap enough and solved my problem.
    Good luck.
