distributor gear wear
Discussion in 'General Truck Forum' started by dijaseedat, Jul 1, 2012.
Tags:
  1. dijaseedat
    dijaseedat Member
    Jul 1, 2012
    retired
    killeen texas
    what would cause a distributor gear wear, where only 1/3 of gear is wore down to nothing, yes the other teeth are wearing about a sixteenth off tooth. This just doesn't make any sense to me at all? Picture 23.jpg Picture 24.jpg Picture 25.jpg
    12,429
    7,514
    what is it in? looks like the bushing is wore in the housing...common with the single bushing type
    If it is out of a chevy vortec a common problem. Dist. gear made of soft composite metal.
    Gets wore mostly on one side from cold starts.. oil pump torque..especially if not using 5w-30 oil in cold climate.
  4. truckabuser1
    truckabuser1 Senior Member
    May 15, 2012
    374
    44
    Uhoh... in my '96 vortec I run 20-50 year around in Michigan....... :rollseyes:
  5. dijaseedat
    dijaseedat Member
    Jul 1, 2012
    retired
    killeen texas
    wow! yeah its out of a vortec 5.7 liter engine. GMC c/k 2500, what is this gear metal made in china or something? Is a autozone replacement worth it or is there a better alternative. Thanks for your help!
    What year? These gears are soft metal cheap gm gears. You need to get a melonized gear a steel gear that has been treated/melonized.
    Vortec have cast cams ...have to have a steel cam for cast cam. Cast ..gear for a steel cam. Can not run steel against steel or cast against cast.
    Will not last long . What engine 305 or 350. have part numbers .
  7. dijaseedat
    dijaseedat Member
    Jul 1, 2012
    retired
    killeen texas
    its a 2000 Gmc c/k 2500, with a 350 in it. Hey thanks!
    Should be this 10457356 google search gm part # will take you to sites that sell it with more info.
  9. gmctrucks
    8,269
    3,856
    You da man super good info.
  10. dijaseedat
    dijaseedat Member
    Jul 1, 2012
    retired
    killeen texas
    Thanks for your help......thankis alot!!!!
