Does Dual Exhaust help performance and mileage?
Discussion in 'Chevy Truck Forum' started by BillSimm, Aug 1, 2006.
  1. BillSimm
    BillSimm Full Member
    Aug 1, 2006
    19
    I have a 2006 Silverado with a 4.8 Liter (Geesh! Whatever happened to the 287?) I had dual exhaust put on it today, flowmaster. Does this really help with performance and fuel economy? If yes, how?
  2. chevyguy
    chevyguy Senior Member
    Sep 21, 2005
    4,094
    85
    Oklahoma city
    What do you mean 287? the answer is yes and no. Some will and some will actually hurt performance do some research before you let someone hack up the exhaust. Make sure ou know that they know what they are doing. Most will add a couple ponies but usually wont hep mileage
  3. BillSimm
    Aug 1, 2006
    19
    The question of "whatever happened to the 287", also meant the 454's, 302's, 350's, 427's...etc. Now everything is in liters. It just doesn't sound right to me.
  4. corey
    corey Full Member
    Jun 30, 2006
    49
    Senior Information Analyst
    Charleston, SC
    Well, then call it the 293. That's the number of cubic inches in the 4.8. ;)
  5. BillSimm
    Aug 1, 2006
    19
    I didn't know that, thanks! Still would like someone to explain to me whether or not dual exhause helps with fuel effeciency and how please
  6. 72'CaminoKid
    72'CaminoKid Senior Member
    Jun 19, 2005
    2,757
    29
    i dont think that it helps or hurts it in either directions to make a noticeable or feasible difference. at least if it's a half-decent job....... as for the cubic inch and liter thing..... liters * 62 = roughly cubic inch measurement, therefore, CI/62 = rough liters
  7. chevyguy
    Sep 21, 2005
    4,094
    85
    Oklahoma city
    Read my above post, it has some good info in there. i am not typing it out twice.
  8. 75K30
    chevyguy tells it like it is, I like that. Maybe, I can expand on his yes and no answer. Did an exhaust modification improve air flow? Yes? Then more than likely you have gained a few more ponies. However, by going to dual exhaust did you sacrifice the crossover that balances cylinder pulses? If you got rid of it, then chances are you have got something that sounds more 50's era, without an improvement in mileage or hp. Exhaust technology has come a very long way, and well designed single systems, can improve power, by freeing up flow, and increase mileage by lowering exhaust temps. Heak the weight savings alone from a stock muffler has gotta be worth 1 mpg. The down side is, that a poorly designed system, can have the opposite effect on your vehicle. Much more info is required to guess at whether or not your new system really helped or not. Pipe size, length, outlet location,exact muffler, stock manifolds, or headers, cats, or no cats? These are all factors in a complete system. A vague question, will get you a vague answer.
