Duramax Coolant Change Questions
Discussion in 'GMC Truck Forum' started by GMCPapa, Feb 15, 2010.
  1. GMCPapa
    GMCPapa Member
    Jan 1, 2009
    I have a 2005 GMC 2500HD Sierra with the Duramax. The manual says the coolant is good for 150,000 miles or 5 years which ever comes first. I have several questions on how I should go about that. It's the first time changing the coolant in this truck so please bear with me. I've done this in cars before by installing a Prestone flushing tee kit in the heater inlet line, draining the coolant, connecting a water hose to the flushing tee and running the engine with the ratiator cap off and the drain valve on the bottom of the radiator open and the water on and flushing the engine. Now I have several questions:
    Can I do the truck like that?
    I see what I think are two black rubber hoses going to the heater. Which one should I put the flushing tee into?
    The manual says use only DEX-COOL (silicate-free) coolant. Is this just to sell me a GM product or Prestone good enough?
    If anyone has any photos of the procedure or have directions I would appreciate a copy.
    Thanks in advance for any help you can provide. I'm like many on a fixed income and have to do many of these things myself. This is an expensive engine and I don't want to mess up.
    Thanks again for any help.
    Papa
  2. davbell22602
    winchester, va
    welcome to the forum
  3. Case 7230
  4. leolkfrm
    12,431
    7,514
    dex-cool is made by texaco, not gm.
  5. BernieB
    BernieB Full Member
    Jul 11, 2009
    3,880
    37
    It's also not rated for use in diesels.
  6. davbell22602
    winchester, va
  7. BernieB
    BernieB Full Member
    Jul 11, 2009
    3,880
    37
  8. leolkfrm
    12,431
    7,514
  9. Crmzendrgone
    Crmzendrgone Senior Member
    Apr 6, 2009
    3,218
    Mechanic. Mr. MOM
    Arizona
    Welcome to the forum. The way I would flush the cummins was just to drain it and then run water through it disconnect the inlet hose to the water pump them disconnect the oulet from the radiator and then run the water through, them put it all back together and fill with whatever % needed where you are at.
  10. BernieB
    BernieB Full Member
    Jul 11, 2009
    3,880
    37
    Yes it does, and it also says to mix it with plain water, which has been proven since then to cause significant damage to any engine using Dex-Cool, not just diesels.
    Read what Mrjohnwayne and I both posted in this thread http://www.truckforum.org/forums/ford-truck-forum/19798-changing-out-the-anti-freze.html and you'll see that Dex-Cool was never intended for use in diesels, doesn't meet ASTM standards for diesel coolants, and has been identified as the reason for many, many engine failures in the last decade.
