Emergency Brake Problem 1994 GMC
Discussion in 'Chevy Truck Forum' started by freeloader, Aug 24, 2010.
  1. freeloader
    freeloader Member
    Aug 24, 2010
    I have a 94 GMC Sierra 1/2 tonne. I'm having a problem with the e-brake. It's very hard, actually, exceptionally hard to push down. Any ideas? Literally, you can't push it down. :(
  2. zombie1969
    zombie1969 Senior Member
    Jun 30, 2010
    1,016
    CT
    Could be a rusted solid cable.Did you take a look at them?
  3. mudseeker
    580
    yup, i had the same problem. good luck finding some at the parts store that aren't "one size fit none"
  4. freeloader
    freeloader Member
    Aug 24, 2010
    Having a look today, I'll keep you posted.
  5. leolkfrm
    12,309
    7,414
    try pulling on the cable along the frame, it too should move freely
  6. freeloader
    freeloader Member
    Aug 24, 2010
    Found the problem. The part of the cable that attaches to the brake shoe emergency lever broke off. So the spring on the e-brake cable on the driver side was being pulled right up against the backplate. Of course you're not going to pull it out, so that's why it was stuck. Replaced both cables and now the e brake works again! Thanks for the suggestions. :D
