Extremely stiff ride '93 c1500 (Indy Pace Truck)
Discussion in 'Chevy Truck Forum' started by Plyc1500, May 31, 2013.
  1. Plyc1500
    Plyc1500 Full Member
    Sep 26, 2010
    17
    Hi All -
    I have two c1500's (a '93 & a '97)... both have stock suspension. The '97 has always ridden very smoothly though, of course, I feel the bumps (I like that kind of road feel).
    The '93 (Indy Pace Truck) has stock suspension but rides like a steel beam. It is the stiffest thing I've ever been in. Hitting even a small bump is almost painful with no give or bounce at all. Is this normal for that truck and what can I do about it... remove rear leaf? Shocks are new gabriel gas shocks.
  2. Boudin
    602
    The first thing I check on these situations is tire pressure. You probably are good, but just trying to cover all the bases. Has the suspension been modified at all from what you can tell? I would think new shocks would help it out. Did it make it worse or better?
  3. Plyc1500
    Sep 26, 2010
    17
    Shocks didn't seem to make any difference... essentially the same steel beam ride.
    I'm going to compare my '97 rear leafs with those on the '93 to see there is any difference.
  4. Boudin
    602
    Hmmm....shocks have one purpose....to dampen the movement up and down as the truck runs over bumps. The particular shocks for your truck is based on the original suspension and ensures that the shock travel will be starting at the normal ride height and cover the distance of the suspension travel. When people alter the suspension to adjust the ride height....if they still have the original style shocks.....the shock travel is limited resulting in the shocks not providing the dampening that they should.
    A lot of people alter their suspensions to make the ride height more level with the front. A 2wd truck comes from the factory with a ride height difference of about 1.5"-2.0" higher in the back so when you load the bed with stuff....it won't squat (back lower than front). Ideally, you want to get shocks that are made for that new ride height.
    I don't know if the pace truck had any special suspension parts or if it was just like a standard 2wd setup. I hate to hear that it is riding so rough. I'm suprised that new shocks didn't change it at all. Is it possible that there might be a "load helper" spring added to the truck? These will make it ride a lot rougher since they basically are made to stiffen the suspension.
    I certainly would take a good look underneath for mods and even count the number of leafs.
  5. gpmorgan
    gpmorgan Auto Banned
    Nov 21, 2009
    2,687
    288
    83
    forklifts and equip tech
    Tupelo Ms.
    I removed one of the leafs, one on each side, on the rear of my 92. Truck now sits level and rides much better.
  6. MikeG
    2,338
    1,408
    Richland, Wa
    The "Pace Truck" addition I'm pretty sure was based on the Sport platform (350 Sport/ 454SS). Those trucks had a little different set up than the normal 2wd trucks, for a "sportier" ride/ handling. You might want to research in that direction to find out what the differeance is. Maybe a dealer (parts counter) can give some insite or web searching. -Mike
  7. Sodell
    Sodell Full Member
    Oct 17, 2011
    968
    385
    NW Arkansas
    Can we get a pic of your 93?
  8. MikeG
    2,338
    1,408
    Richland, Wa
    I found ouy the sport package (code BYP) from, Welcome To My Newest Bit Of Nothing!. I also pulled this info from: Chevrolet C/K - Wikipedia, the free encyclopedia .........
    I found this in info on the 454SS so I'm not sure if it applies to the Indy or even the 350 Sport for that matter. I'm having a hard time just narrowing down the Indy or Sport info.
  9. MikeG
    2,338
    1,408
    Richland, Wa
    I found something else on Factory Sport Trucks ........
    And also from Vehicle Information Kits - GM Heritage Center
    http://www.gmheritagecenter.com/doc...its/Chevrolet-Trucks/1993-Chevrolet-Truck.pdf
  10. Plyc1500
    Sep 26, 2010
    17
    Thanks for all the help.
    I did look at the rear springs and there are 4 like my other truck ('97 Cheyenne) but they measure about a 1/4" thicker (ea)... which, times 4 will give me an extra inch of stiffness. I'm going to try the removal route and see how that goes. I never carry/haul anything heavy so that shouldn't be an issue. Truck does have those super-wide Indy Firehawk rear tires also. Might put on my extra set of std Dunlops & see if that helps.
    Again... thanks
