F250 speedo not working
Discussion in 'Ford Truck Forum' started by Robert78.5, Dec 4, 2009.
  1. Robert78.5
    Robert78.5 Full Member
    Sep 10, 2006
    101
    Sales manager
    Manitoba
    We changed the sender unit on trans, now we changed the instrument cluster with a Ford rebuilt, still no speedometer. Where to look next? year 2000 automatic 2 wd gas,
  2. mrjohnwayne
    mrjohnwayne Full Member
    Apr 15, 2005
    4,062
    101
    Oil and Gas field
    vss on these trucks is located on the rearend. also doubles as the abs sensor.
  3. Robert78.5
    Sep 10, 2006
    101
    Sales manager
    Manitoba
    What does the sensor on transmission do than?
  4. davbell22602
    winchester, va
    it sends a signal to the speedometer telling it how fast you are going.
  5. Robert78.5
    Sep 10, 2006
    101
    Sales manager
    Manitoba
    Thats what i figured but why does speedo not work?
  6. mrjohnwayne
    Apr 15, 2005
    4,062
    101
    Oil and Gas field
    the sensor on the tranny is also used as a speed measuring device... but the one that controls the speedo is on the pumpkin on the rearend. and I might have told you wrong. there might be 2 sensors on the rear end. depending if your truck is 2w abs or 4w abs.
    pretty sure you change the vss on the rearend and you'll get the speedo back.
    Case 7230 likes this.
  7. Robert78.5
    Sep 10, 2006
    101
    Sales manager
    Manitoba
    ok will try
  8. eponator
    eponator Senior Member
    Nov 26, 2008
    772
    11
    SO Cal
    JW beat me to it, check your VSS on top of the rear diff facing the front of the truck. If you find allot of metal flakes or dirt / grime built up on the end of it then clean it up, stick it back in and go for a drive. Sometimes its just dirty and cleaning it will get you back on the road quickly.
    If this doesn't work then I'd replace it. Cheap part, simple fix, its pretty self explanatory.
    You mind me askin how much that recalibrated speedo set ya back?? OH and are you tripping any ABS lights?? Any codes being thrown?
  9. Robert78.5
    Sep 10, 2006
    101
    Sales manager
    Manitoba
    #9 Robert78.5, Dec 9, 2009
    I changed it now it works. should have tried that before changing cluster,
  10. eponator
    Nov 26, 2008
    772
    11
    SO Cal
    Glad we could help you get it working right again! Now, got any pics of that truck??
    :D
