flooding '93 cheyene 5.7
Discussion in 'Chevy Truck Forum' started by elboriqua, Mar 16, 2011.
Tags:
  1. elboriqua
    elboriqua Full Member
    Nov 19, 2010
    12
    #1 elboriqua, Mar 16, 2011
    Hello every one, here is my problem. I have a 1993 chevy cheyene with a 5.7 and tbi. it is flooding realy bad there are no codes i have look for thread ond this problem and i have done some of what was sugested like disconecting egr, map censor and replased the temp sensor. any sugestion any one?
    22,406
    13,169
    I would change temp sensor.. the one beside thermostat housing.
    Reading -22 degrees ecu adding more fuel.
    Cost 10 bucks change it then see/ get it out of the equation.
    Have had them go bad with .. no codes.
  3. elboriqua
    Nov 19, 2010
    12
    I did replased the temp sensor, and i forgot to mention i chainge the fuel presure regulator to.
    22,406
    13,169
    Ok ... take a look at your injectors. Should be a nice cone shape pattern.
    Look for any drops in or around cone pattern. Are you sure your check engine light is working.
    Maybe bad 02 sensor. Any leaks around tbi gaskets?
  5. elboriqua
    Nov 19, 2010
    12
    Yep engine light is worcking, I used an obd2 scaner and i dont get any codes. But now that i think about it some of mi gages arnt workin, like the tep sensor fuel and oil.
  6. elboriqua
    Nov 19, 2010
    12
    ok guys time for me to go crash i gat to be up at 3am ill check back in the mormig hope you guys put me in the wrigh direcion. thancks.
  7. crabtruck
    Welcome to the forum elboriqua.
    Little confused here...you used a OBD-II scanner on OBD-I truck ?
    How do you know check engine light works ?
    If flooding, would think you would get a code for too rich.
    Suggest you pull codes with a paperclip, so you are sure.
    http://www.truckforum.org/forums/chevy-truck-forum/13388-service-engine-light.html#post58041
    Poor grounds can do this several ways.
    Can cause static in IC mod which computer thinks wants more gas.
    Can cause poor signal from TPS looking like accelerating.
    This comes more to mind because of guage failures.
    Does volt guage read correctly ?
    Could be caused by vac leak but would think disconnecting MAP
    would have caught that.
    Any recent work or mods to truck ?
    As chevychase said check the injector spray pattern.
    Could be leaky or might be signal wire shorting to ground.
  8. elboriqua
    Nov 19, 2010
    12
    Flooding
    I know what you mean by using the obd 2 but it work i even pull the engine scan. i just got to lock up the number that it gave me on all the sensors. I did the paper clip before i use the scaner and all i got was the dignastic code 12. Theres no mod on the truck. i will start checking all the grounds and pull out the cluster gage to see if i find what is wrong there.
  9. crabtruck
    Cool, it's not an OBD2, it's a combo reader, have one of those.
    I wouldn't go straight for the cluster, think what's common.
    Closest ground I think is right at ALDL/OBD connector.
    While your at it there's a ground on the frame rail under driver.
    Common problem areas are front and rear of eng top, and the braids
    Does the volt guage read correctly ?
  10. elboriqua
    Nov 19, 2010
    12
    #10 elboriqua, Mar 19, 2011
    Hello every body, i have been busy with work so i havent been able to worck on my truck. Hey crabtruck ill leave the cluster alone for now, and ill check all the ground conections towmorow. As it matterfac the volage gauge it reads way to hi if i remember it was around 18 to 19 volts. ill let you guys know if i find anything. Hey chevy chace The spray patern on my injector its an iven cone shape exept that when it idles the left side injector sprays more then the right one and when i open the throtle it looks more even.
