Foamy looking tranny fluid
Discussion in 'GMC Truck Forum' started by 95oneton, Nov 26, 2010.
  1. 95oneton
    95oneton Senior Member
    May 26, 2010
    54
    I went out and checked my tranny fluid this morning while my rig was cold and it was really foamy looking. Is this normal ? Its a 95 auto jimmy. I find when driving on the highway and you speed up it revs up alot before it shifts. Not sure if this is normal or not. Also when you put it in overdrive it doesnt seem to work right almost like it surges a little. I've always been paranoid of blazers and jimmys cause of the trannys. Mayby its nothing.
  2. silverhairdeere
    silverhairdeere Senior Member
    Feb 15, 2008
    1,831
    33
    disabled
    land between the lakes tn
    If it's not cherry red or it smells burnt change it and the filter
  3. 95oneton
    May 26, 2010
    54
    The fluid was still really red. I just never seen it foamy like that before. Wasnt burnt smelling or didnt seem gritty.
  4. scavanger
    scavanger Full Member
    May 15, 2007
    1,676
    1,239
    are you sure it isn't overfull. Was the foam white? if so you may have a cooler leak in the radiator.
    Scav.
  5. OssipeeSteve
    OssipeeSteve Senior Member
    Mar 6, 2008
    238
    44
    Retired Tel.Tech among others
    Plymouth, MA
    Never had lag in shifting but did have the foaming when it was overfilled. Syphoned extra out of filler tube and was OK.
  6. 95oneton
    May 26, 2010
    54
    It was at the cold mark when i checked it. It didnt seem overfull. I'll check it today when i take it in town while its hot. I guess it was more bubbley then foamy. It wasnt really white. It only seems to rev up before it shifts ito forth. Not sure if that normal or not.
