front wheel bearing/hub assembly on a 2001 Dodge Ram 1500
Discussion in 'Dodge Truck Forum' started by Space Ace, Apr 25, 2008.
Thread Status:
Not open for further replies.
  1. Space Ace
    Space Ace New Member
    Apr 25, 2008
    I'm replacing the front wheel bearing/hub assembly on a 2001 Dodge Ram 1500 with 4WD and rear wheel antilock brakes. I have removed the wheel, caliper, caliper holder, rotor, hub nut and the three bolts holding on the bearing/hub assembly. From what I have read, it is common for the bearing/hub to become seized onto the axle. This is true in my case. I used a wheel puller to try and remove the hub bearing and all that came off was the front part of the assembly that attaches to the axle leaving the back part of the assembly still on the vehicle.:eek: I don't see anyway that I can use the wheel puller to help me remove this portion. I'm looking for any ideas that would help.
    :confused:
  2. stumpuller454
    Dec 26, 2007
    2,206
    65
    Use a block of steel approximatley 2" in size, have someone start the vehicle, turn the wheel, install the block so that it is "pinched" between the axle housing and the u-joint spindle, have them trun the steering wheel to "squish" the block this will put pressure to push hub off, may need to pinch it on both sides to break it loose. (in front and behind axle) and if its really stuck a dead blow aswell, this system i`ve never had to use heat, good luck and wear gloves and saftey glasses...highly recommended, don`t pinch your fingers either!!
  3. mudseeker
    581
    x2 on the safety glasses suggestion:eek:
  4. pclizard
    pclizard New Member
    Oct 8, 2008
    I just replaced mine and the book said 175lbs of torque on the hub nut. That seems a bit extreme to me, I've burned out bearings before by overtightening them before. Should I be concerned about the torque specs or does this sound reasonable?
  5. mudseeker
    581
    sounds right, my chevy was around 150-200. 2 wheel drive is a different story though.
  6. pclizard
    pclizard New Member
    Oct 8, 2008
    Thanks, I was a bit worried. The hub was $120 here in Missouri. I didn't want to replace it again for following bad instructions.
  7. bradrhale
    maybe i should stop giving advice. while reading this, i thought about the last one i tightened. i ran it up with a 3/4 impact and moved the hub with my hand until i thought it was tight enough. still have no interest in buying a torque wrench. i can use that 6 or 7 hundred dollars somewhere else. before we bought the right socket, we used a chisel and hammer.
  8. FaselZ71
    FaselZ71 Senior Member
    Oct 4, 2008
    1,177
    Unemployment!!!
    Northern Michigan
    WOW 6 or 7 under dollars for a torque wrench that thing better me made of gold. I've seen them at advance auto parts for like $30-70.
  9. bradrhale
    1" wrench. 4 ft long. and not made out of gold. i do have a 3/8 like what you are talking about though.
  10. FaselZ71
    Oct 4, 2008
    1,177
    Unemployment!!!
    Northern Michigan
    ohh. ok duh I didn't notice it was 3/4 or 1". My bad yeah I got the little dinky ones haha
Thread Status:
