fuel filler assembly
Discussion in 'Chevy Truck Forum' started by jestructure, Feb 7, 2007.
  1. jestructure
    jestructure Member
    Feb 7, 2007
    Hi all, I am looking for a replacement for the fuel filler assembly for my 85 chevy 3/4ton long bed. cant seem to find any supplier.
    Anyone know where I can get this thing. Thankyou.
  2. mrjohnwayne
    mrjohnwayne Full Member
    Apr 15, 2005
    4,062
    101
    What kinda assembly are you talking about?
  3. jestructure
    jestructure Member
    Feb 7, 2007
    I am looking for the fuel filler neck and ruber hose and steel pipe that
    carry the fuel into the fuel tank. The assembly consists of about 5 pieces
    including the rubber vent hose.
    thanks
  4. westboundchevy
    westboundchevy Full Member
    Jan 7, 2007
    40
    you must be havinmg the same trouble that I am, on my 85 silverado... the stock tank is 19 gal, but the replacement is only 16... meaning that the old filler neck doesn't quite line up...
    i'm thinking about fixing the leak in my tank, rather than replace it with this smaller one that doesn't fit right...
    but if i kept the smaller tank, i was gonna take the parts to Napa, and see if they could hand me some longer ones that i can cut to length and clamp in place. should be a pretty cheap fix.. maybe 20 bucks.
  5. mrjohnwayne
    Apr 15, 2005
    4,062
    101
    ah gotcha. didnt read it right the first time. thought you said fuel filter assembly.
  6. jestructure
    jestructure Member
    Feb 7, 2007
    I am just trying to replace my stock filler assembly.... the metal tubes have rusted thru and i dont seem to be able to locate any replacement parts for this. I tried having a local exhaust shop custom bend one for me but they say they cannot bend the 1-3/4" dia tube in that tight of a radius.
    Anyone have used assembly they want to sell ?
  7. westboundchevy
    Jan 7, 2007
    40
    mine is only two pieces of rubber, with some clamps... would that work on yours?
  8. jestructure
    jestructure Member
    Feb 7, 2007
    The assembly I have consists of the steel filler neck then 4" section of hose then bent steel section, then 4" hose to gas tank.
    I could probably re-use the hose sections but the filler neck and steel tube are rusted thru.
    thanks
