Fuel pump not shutting off
Discussion in 'Chevy Truck Forum' started by Steven Davis, Jan 13, 2018.
  1. Steven Davis
    Steven Davis New Member
    Jan 13, 2018
    I have a 93 Silverado 5.7 the fuel pump will not shut off when the truck is turned off in the key out I have replaced the fuel pump relay and I have replaced the oil sending unit not sure what to do next it is running the battery down
  2. MikeG
    2,803
    2,070
    Richland, Wa
  3. MikeG
    2,803
    2,070
    Richland, Wa
  4. hatzie
    hatzie Full Member
    Mar 17, 2014
    397
    730
    Northern New England
    Have you tried unplugging the Hot Fuel Handling relay?
    It's there to prevent vaporlock by running the fuel pump for 20 seconds after key off when the outdoor temps are high.
    If it malfunctions the fuel pump can run without the ignition switched on.
    1993 CK series service manuals folder --->MediaFire 1993 T400 Manual Folder
    Look in the 1993 GM CK wiring manual on PDF page 272 for the hot start relay location.
