Fuel Pump will not turn on?
Discussion in 'Chevy Truck Forum' started by cab41610, Jul 15, 2006.
  1. cab41610
    cab41610 New Member
    Jul 15, 2006
    :confused: When i go to start the truck it cranks, and cranks, but not fire. I have a good battery, good spark, but no fuel is getting to the throttle boby. I have replaced the fuel pump, and all wiring inside the gas tank. The fuel pump will not turn on. I have also replaced the fuel fitler & the relay and no change. I am just not getting any power to the fuel pump.
    Any suggestions?
  2. 72'CaminoKid
    72'CaminoKid Senior Member
    Jun 19, 2005
    2,757
    29
    sounds like thats the problem to me
  3. cab41610
    cab41610 New Member
    Jul 15, 2006
    Any suggestions on where to look for the power lose?
  4. 02F2504x4
    02F2504x4 Senior Member
    Jan 2, 2006
    88
    Salesmen
    Cali
    get a wire diagram for your truck and a volt meter and chase down your porblem could be a split wire or something also check your fuses.
  5. 72'CaminoKid
    Jun 19, 2005
    2,757
    29
    agreed ^^^^^ you may need to drop the tank and check the coltage at the fuel pump, this should tell you if your getting any power to it
  6. mudseeker
    580
    just get a mechanical pump, i hate all the electrical stuff.:D
  7. 72'CaminoKid
    Jun 19, 2005
    2,757
    29
    i agree with that even more. mechanical pump is safer anyway
  8. 88chev
    88chev Full Member
    May 28, 2006
    35
    i would definitely check your fuses first and then go through and check all your wiring to your pump.
