Gear Drive with Knock sensor?? Compatible or Not....
Discussion in 'Chevy Truck Forum' started by thegreenfortnox, Feb 7, 2011.
  1. thegreenfortnox
    thegreenfortnox Full Member
    Jul 23, 2010
    41
    I have a 96' chevy with vin "r" vortec engine. I want to put gear drive on this engine and want to know if anyone has found a kit to do this on this engine and if it causes problems with the knock sensor or timing problems due to knock sensor. Please let me know if it would work ok and if it did, do you know where you got it?? Will I have to get a different timing cover??
  2. thegreenfortnox
    Jul 23, 2010
    41
    wow.. nobody knows??
  3. 79mudder
    79mudder Member
    Feb 7, 2011
    i dont know of one that will work because the gear drive puts out harmonics even the "quiet" ones and the knock sensor sees that harmonic as a knock
  4. 87c10slammer
    87c10slammer Senior Member
    Mar 20, 2008
    3,221
    49
    noisey gear drives wont work with a knock sensor.. better off getting yourself a good double roller.
  5. thegreenfortnox
    Jul 23, 2010
    41
    i figured... thanx
