gear ratio codes
Discussion in 'Chevy Truck Forum' started by grasshopper, Feb 9, 2010.
  1. grasshopper
    grasshopper New Member
    Aug 20, 2009
    Does anybody now where to find the gear ratio codes and what they are. I was looking at a 07 chevy 1500 and wanted to now if it has the right gear ratio in it. i'm wanting a 3.73
  2. davbell22602
    winchester, va
    Mine is the 3.73, 9.5, 14 bolt. Count the bolts on the diff cover.
  3. grasshopper
    Aug 20, 2009
    Ok, i will check them out thanks for the info.
  4. hotrodpc
    hotrodpc Full Member
    Jul 29, 2008
    7,277
    110
    Moore, OK
    Welcome to da fowum grasshoppa !!! What you mean by codes??? Are you wanting RPO glove box codes?
  5. hotrodpc
    Jul 29, 2008
    7,277
    110
    Moore, OK
    Here are a few. Look in the glove box for 3 digit codes starting with G. G80 just means its Gov-Lok locking diff, so you could have another G code also. If yours is not listed, let us know what it is, and I am sure we can get it for you.
    GN9 : AXLE REAR, 4.11 RATIO
    GQ1 : AXLE, STD RATIO
    GS1 : AXLE REAR, 2.73 RATIO
    GS3 : AXLE REAR, 3.73 RATIO
    GS4 : AXLE REAR, 3.70 RATIO
    GS5 : AXLE REAR, 4.11 RATIO
    GS6 : AXLE REAR, 4.56 RATIO
    GT1 : AXLE REAR, 2.56 RATIO
    GT2 : AXLE REAR, 2.29 RATIO
    GT4 : AXLE REAR, 3.73 RATIO (DUP WITH 5 X 1)
    GT5 : AXLE REAR, 4.10 RATIO (DUP WITH GT8)
    GT7 : AXLE REAR, 3.33 RATIO
    GT8 : AXLE REAR, 4.10 RATIO (DUP WITH GT5)
    GTY : AXLE, WIDE TRACK
    GU1 : AXLE REAR, 2.41 RATIO
    GU2 : AXLE REAR, 2.73 RATIO
    GU4 : AXLE REAR, 3.08 RATIO
    GU5 : AXLE REAR, 3.23 RATIO
    GU6 : AXLE REAR, 3.42 RATIO
    GV1 : AXLE REAR, 2.73 RATIO
    GV2 : AXLE REAR, 5.83 RATIO
    GV3 : AXLE REAR, 3.08 RATIO
    GV4 : AXLE REAR, 3.36 RATIO
    GV5 : AXLE REAR, 3.55 RATIO
    GV7 : AXLE REAR, 4.11 RATIO
    GV8 : AXLE REAR, 2.72 RATIO
    GW2 : AXLE REAR, 2.56 RATIO
    GW3 : AXLE REAR, 2.56 RATIO
    GW4 : AXLE REAR, 3.31 RATIO
    GW5 : AXLE REAR, 2.73 RATIO
    GW6 : AXLE REAR, 3.27 RATIO
    GW8 : AXLE REAR, 4.10 RATIO​
    GW9 : AXLE REAR, 2.93 RATIO (DUP WITH GU3)
  6. davbell22602
    winchester, va
    Mine is a GT4
  7. hotrodpc
    Jul 29, 2008
    7,277
    110
    Moore, OK
    You wanna see a rare one? My truck has HC8 for the rear end gear ratio. Its in a full floater 14 bolt. 3.21 ratio. Wussy station wagon gears. No biggie, I use it to my advantage. I also have the Full Floater with 4.10's and a 14bolt Semi Float with 4.10's.
