GT4 Rear End???
Discussion in 'Chevy Truck Forum' started by Fatcat, May 4, 2010.
  1. Fatcat
    Fatcat Senior Member
    Jun 21, 2008
    89
    I have a 2000 Chevy Silverado 4x4 and I need a new rearend for it. I was told I need a GT4 rear end which i am pretty sure is a 3.73 ratio? i was wondering if i could install a GT4 rear end from a 2wd in my 4x4 truck, if it makes any difference?
  2. ChevMan92
    ChevMan92 Senior Member
    Jan 20, 2010
    155
    i think you can, as long as the gears are the same in the front and the rear
  3. Fatcat
    Jun 21, 2008
    89
    ok thank you i was pretty sure i could i just wanted to check
  4. ChevMan92
    Jan 20, 2010
    155
    u can put any gm axle in that you want as long as it has your gear ratio
  5. Fatcat
    Jun 21, 2008
    89
    ok thanks for ur help i appreciate it
