Heat issue
Discussion in 'Chevy Truck Forum' started by Jprice2ndlt, Dec 22, 2016.
  1. Jprice2ndlt
    Jprice2ndlt Full Member
    Oct 1, 2015
    70
    91
    i have a 94 k1500 when I first bought it the heat was super hot but the heater core was leaking. I bought a new heater core replaced it but now it only gets warm and not hot. What could be going on
  2. kbrown11
    kbrown11 Full Member
    Dec 5, 2015
    1,233
    2,158
    Alburquerque
    I would try a thermostat. I think the thermostat maybe opening too soon, not letting the truck warm up enough.
  3. Jprice2ndlt
    Oct 1, 2015
    70
    91
    I put a new 190 degree thermostat when I put in the motor. Could that be the issue
  4. kbrown11
    Dec 5, 2015
    1,233
    2,158
    Alburquerque
    No, i think the temp of that thermostat is ok. How long ago did you do the heater core? One other possibility is air in the system if you just recently did the heater core.
  5. Jprice2ndlt
    Oct 1, 2015
    70
    91
    I redid the heater core about a year ago when I replaced the motor but I had other problems as well and never really got to drive it to test it. Got it running this summer then the transmission went out and just got it back in time for winter. How do I check for air
  6. kbrown11
    Dec 5, 2015
    1,233
    2,158
    Alburquerque
    I think after that long it should have burped itself. Usually all you have to do it drive it and over a couple of days all the bubbles come out of the system. I had bought a brand new thermostat for my car last year because the heat wasn't working. I replaced the thermostat and it fixed it. About one year later that thermostat went bad and the car would not heat up. I replaced it again and that fixed the problem, nice and warm now. The thermostat I bought last year was from Autozone, this new one I bought from Napa.
  7. Jprice2ndlt
    Oct 1, 2015
    70
    91
    Will have to check the thermostat I notice that it never gets over 170 on my gauge so maybe I should try a different one
  8. kbrown11
    Dec 5, 2015
    1,233
    2,158
    Alburquerque
    You could also check to make sure that the heater core is not plugged. Warm the truck up and turn on the heater. Feel the two hoses going to the heater core, they both should be warm/hot. If the inlet hose is warm/hot and the outlet hose is cool, your heater core maybe plugged up.
    leolkfrm likes this.
  9. Jprice2ndlt
    Oct 1, 2015
    70
    91
    Ok thanks for the input
  10. leolkfrm
    7,920
    give it a quick back flush when you change the t-stat cant hurt, might have sent some garbage into it from the engine change
