Heated seats fuse?
Discussion in 'GMC Truck Forum' started by jesusdrivesagmc, Feb 11, 2007.
  1. jesusdrivesagmc
    jesusdrivesagmc Full Member
    Feb 11, 2007
    11
    Which fuse is the heated seats under in my '99 suburban. In the fuse block in the driver side of the dash, the fuse identifier label on te fusebox cover doesn't list anything for heated seats. I am assuming it is a fuse, because both stopped working since last winter. :confused:
  2. mrjohnwayne
    mrjohnwayne Full Member
    Apr 15, 2005
    4,062
    101
    check the manual. There should be a layout in there for the fuses.
  3. jesusdrivesagmc
    Feb 11, 2007
    11
    control unit?
    Do late model trucks like mine have a seperate control unit/box that is associated with the heating system in the seats? If so, do those go bad and where are they located usually? Thanks.
  4. gmtech
    gmtech Senior Member
    Dec 3, 2005
    348
    Underhood fuse block there is a 20a fuse for both heated seats.
