Help with Tires for 87 R10 Silverado
Discussion in 'Chevy Truck Forum' started by Pfhealey58, Oct 1, 2012.
  1. Pfhealey58
    Pfhealey58 New Member
    Oct 1, 2012
    Hello fellow chevy truck lovers! I am restoring an 87 r10 and I'm looking to put larger tires on it. Currently I have 235/70-15. I am concerned about rubbing in the wheel well. What is the best size to give it that heavy duty pick up look? All suggestions are welcome. ​
  2. MikeG
    2,317
    1,376
    Richland, Wa
    You could probably run a 245, maybe a 265. Are you putting on aftermarket rims? If so depending on the back-spacing will depend on the width you could run. I would check with a 4wd/ off-road shop to see what the biggest is you can go with for your application.
  3. Pfhealey58
    Oct 1, 2012
    I was planning on keep the stock rims. I just wasn't sure if 255 was too big?
  4. MikeG
    2,317
    1,376
    Richland, Wa
    The farmer I am renting from has a K10(????) on the property, same body as yours. His rig is running 255's on it with the factory steel wheels. Although his truck might be a late '70's.
  5. batty1214
    batty1214 Senior Member
    Nov 2, 2008
    2,269
    495
    Mine Mechanic(tire guy)
    Vernal Utah
    the 235 is a 28" tall, 9.4 " wide tire........ the 255 is a 29" tall, 10.2 wide..... Im betting you'd be okay....
  6. Sodell
    Sodell Full Member
    Oct 17, 2011
    968
    385
    NW Arkansas
    265's should be OK if you have a 4x4.
  7. hotrodpc
    hotrodpc Senior Member
    Jul 29, 2008
    7,277
    110
    Moore, OK
    R10 is 2wd. So what are you looking for in a bigger tire? Taller tire or Wider Tire? Or Both? Is there a purpose for the larger tire? Going for just better looks? Better Mpg? More traction?
  8. Pfhealey58
    Oct 1, 2012
    There's no real purpose. I just think that the 235 looks small in the wheel well And that a 255 might give it that true pick up look.
