how do i remove the door windows in a 86 chevy c10?
Discussion in 'Chevy Truck Forum' started by brandon74, Jul 14, 2009.
  1. brandon74
    brandon74 Member
    May 4, 2009
    i need help removing manual door window in a 86 chevy c10 single. help!!!:help:
  2. mrjohnwayne
    mrjohnwayne Full Member
    Apr 15, 2005
    4,062
    101
    remove the door panel, unbolt the window regulator from the door. Make sure you have an extra hand if possible becuase the glass is fairly heavy. once the regulator is unbolted you can use the handle to crank the regulator and you will see (in the middle of the glass frame) a cut out for the wheel to come out. once you have one wheel out you can slide the regulator assy which ever way necessary to remove the other wheel. I'm not sure if you will need to remove the vent window first or not though. It has been several years since I have done this.
    Hope it helps.
  3. csracing93
    csracing93 Full Member
    Nov 6, 2008
    39
    if you take the inner panel off, you will see the regulator that holds window in track.
    look on the track and you will see notches foe the window wheels, crank window up or down till wheels line up to slots and remove window
