How do I swap engines from 84 carbureted 350 chev blazer to 92 f/i chev truck?
Discussion in 'Chevy Truck Forum' started by jerseyduck7, Oct 15, 2010.
  1. jerseyduck7
    jerseyduck7 Member
    Northern Ontario, Canada
    Hi guys.... I just bought a 92 fuel injected chev stepside 4x4 for my son and want to put in the engine from my carbureted 1984 350 chav blazer. Will this work? Any special way it has to be done? Keeping it fuel injected would be a plus..... Please help.
    22,214
    12,851
    Your talking a lot of work. If i was going to swap leave it carbed.
  3. cburcham73
    cburcham73 Senior Member
    Aug 22, 2008
    305
    electrician
    williamsburg virginia
    swap in the engine,and the computer,sensors and wiring. you will need a electric fuel pump with new lines. are you swaping the trans also?
  4. bradrhale
    dont forget to block off the mechanical fuel pump port on the side of the block.
  5. wyochimneysweep
    wyochimneysweep Senior Member
    Mar 26, 2010
    315
    Diesel Tech
    Fargo ND
    he's putting the carb engine into the chevy pickup thats already fuel injected. its easy. take off the mech fuel pump and transfer over block off plate. next you need to modify the center holes on the tbi intake manifold. the holes are at different angles. just oblong the holes till you can put bolts in and tighten them to snag but not to tight or you'll crack the manifold. its pretty easy.
  6. sbc 350
    sbc 350 Full Member
    Sep 3, 2010
    I just completed a similar swap out I put a 1980 carburetor V-8 350 in a 1995 that had a vortec V-6 EFI and a standard transmission it was a little more work then you will be in for because I had to change motor mounts and fan shroud from the V-6 to V-8, but I could use the serpentine belt system off of the V-6 it mounted up fine except having to change the water pump from an 80’s model to the 90’s model (serpentine systems run the pump in the opposite direction) I also went with the mechanical fuel pump and pulled the electric fuel pump relay (too much pressure). Swapped out the Oil/water temp sending units with the 95’s and Ran a hot wire from the terminal box (it has to be hot even with the key in the start position) to the Distributor and re-worked the throttle linkage and it runs fine and all the gauges work fine hope this helps.
  7. BGarth
    BGarth New Member
    Oct 19, 2010
    welder
    New Orleans
    Hope I'm not stealing the thread...I have a 96 Vortec 350 that's already carbureted, what would be involved with putting this in my 95 with 4.3 TBI? I do not want injection on the 350. It would break my heart to 86 the computer altogether
  8. rdhack
    rdhack Senior Member
    Jun 29, 2008
    184
    Science Education
    kentucky
    Seems to me that you could simply exchange the intake maniford from the FI engine to the carbed engine along with all other emissions junk.
