K1500 upper ball joints, Bolted or riveted?
Discussion in 'Chevy Truck Forum' started by diceman1994, Jul 26, 2010.
  1. NSguy
    NSguy Senior Member
    Jul 23, 2010
    242
    Forestry Contractor
    Port Hawkesbury, NS
  2. mudseeker
    584
    :rofl:
    sorry, i feel bad for you.
    :rofl:
    really..... i do, but it's just too dang funny!
  3. HeavyBurban
    HeavyBurban New Member
    Sep 18, 2010
    hardwork
    memphis
    cut off wheel and a BFH
  4. Oldmech
    Oldmech Full Member
    Jan 12, 2010
    1,763
    214
    Iowa
    working for chevrolet, I did a lot of these, the secret, is to cut the heads off with the air chisel, or just a hammer and chisel, they cut pretty easy.. then, before takign a punch to them, take a drill, and drill down into the center of the rivet, leaving plenty of shoulder for your punch.. the hole you drill down into the rivet, allows the rivet to collaps INWARD rather than mashing itself against the walls of the a arm, and they pound out MUCH easier... You do not need to drill all the way through, just far enough so that when you drive the rivet down, the expansion has a place to go rather than OUT... the rivets are soft steel, they cut easy, and drill easy, but they also smash easy when your pounding on them... once you have them all driven out, yes, you bolt the replacements in. You can do it in your garage easy enough. an air chisel with a punch the right size for the rivets that fit the air hammer are a major boon, no torch required.
  5. ndh87
    ndh87 Member
    Dec 9, 2007
    The stock ball joints were riveted. Just take a drill and drill the center of the rivet then cut the head of it off with a grinder, new ones will bolt right in through the same holes.
  6. BGarth
    BGarth New Member
    Oct 19, 2010
    welder
    New Orleans
    Uppers on my 95 were riveted on...I used a grinder on the heads then beat them out. The replacement ball joints will come with bolts. It was kind of a pain until I stopped being shy with the grinder. The first side took 2 hours, second side...15 minutes
  7. bp2930
    bp2930 New Member
    Oct 26, 2010
    Hey guy I'm restoring an 89 Chevy 4x4 if you do it yourself you will save a bunch its not hard at all. I did mine in one day. The only difference with riveted joints is you have to drill them out. Cut the heads off with a grinder or air chisel. I suggest to get the Chilton book for your truck all the steps are there. The main points when drilling is that you drill a pilot hole with a very good drill bit and drill and use a steeped titanium drill bit to do the main drilling you can get one at Habor Frieght. I did mine and its a 4x4 a two wheel truck is not going to be that bad. If you have any questions email I changed all my own front end parts, just read the manual and get aligned when you are finished. You might as well change your other front end parts while doing that The money you save you could buy those parts to do it.
    GOOD LUCK
  8. 2324tigers
    2324tigers New Member
    Jan 22, 2012
    pita
    Just got done doing the upper and lower ball joints on a 96 k1500 4x4. Everything was simple until the last rivet of the upper ball joint. That thing would not come out for anything. I think I may have ground a little too much and welded the tops of the rivets to the control arm. Dremel cut off wheel and hammer made easy work of the others. Good luck. On the install, lower ball joint was a pain to push in straight. Other than that, straightforward.
