lift not level
Discussion in 'Chevy Truck Forum' started by dd444, Aug 15, 2006.
Thread Status:
Not open for further replies.
  1. dd444
    dd444 Member
    Aug 15, 2006
    I have had this truck a year and put the lift and tires on myself..But would like to have it more level than the kit I used left it.Any ideas??
  2. mrjohnwayne
    mrjohnwayne Full Member
    Apr 15, 2005
    4,062
    101
    Oil and Gas field
    Shackle flip in the rear, lift blocks, or new rear springs. That's the only way I can think of.
  3. 72'CaminoKid
    72'CaminoKid Senior Member
    Jun 19, 2005
    2,757
    29
    i'm tryin to figure how the front is so much higher than the back, espicially with all the engine weight up front
  4. 64longstep
    64longstep Senior Member
    Aug 14, 2006
    former truck driver
    PHX.AZ
    what type of lift kit did you use?
  5. mudseeker
    581
    i would go with new rear springs. did the back sag before the lift? did you use the same size blocks in the front and back?
  6. dd444
    dd444 Member
    Aug 15, 2006
    It was a rough country lift kit it had new springs for the front and blocks for the back.I'm wondering if once the springs get broke in if it will be more level?
  7. 64longstep
    Aug 14, 2006
    former truck driver
    PHX.AZ
    dud, you need to replace your back springs, they are sacked out.
  8. chevyguy
    chevyguy Senior Member
    Sep 21, 2005
    4,094
    85
    Oklahoma city
    yip, replace rear springs,or use add a leafs
  9. chevyman_03
    chevyman_03 Senior Member
    May 26, 2007
    101
    wutever needs to be done
    Georgia
    wow, ive never seen a truck with a lift sit that way before... but yea shackle flips, bigger blocks, or ad a leafs
  10. chevyguy
    Sep 21, 2005
    4,094
    85
    Oklahoma city
    I think the company might have sent you a 4 inch lift for the front and a 2.5 for the rear. Either way add a leafs will help, If you do a shackle flip you will get about 4 inches, but then it becomes squirrley on the road and wont tow anything and still be drivable at higer speeds
Thread Status:
