location of electronic spark control module 1995 chevy.
Discussion in 'Chevy Truck Forum' started by ranger1958, Aug 11, 2011.
  1. ranger1958
    ranger1958 Full Member
    Aug 11, 2011
    21
    I need help locating the electronic spark control module on a 1995 chevy truck. Some think that it's on the bracket the map sensor, but it's not there. It's there on the earlier models but not the 95. Any help would be appreciated.
    22,214
    12,851
    You will not find it it is integrated in the ecm/ computer... you may still have the braket for 88 to 93.
  3. ranger1958
    Aug 11, 2011
    21
    So if I'm getting a code that says it's not working, then I will need a new computer?
    22,214
    12,851
    No not necessarily... which code are you getting 42, 43? Could be a few things wrong... knock sensor bad, Connections at ecm loose, weak ign. module ect.
    First thing to do clear code drive see if it comes back. What symptoms do you have?
  5. ranger1958
    Aug 11, 2011
    21
    The check engine light is on. Here is what happened, swapped out a motor. Truck was running fine just over 230,000 it was starting to use oil and leak some. Upon installing new motor we forgot and left the - battery cable unhooked the small braided bonding strap took the full amperage. after the ground cable was installed the check engine light was on. Can't remember the number but the code reader said electronic spark control module failure. Truck will run, but sluggish and runs rough at times. As soon as you clear the code it comes right back and each time the same thing. I think without the proper ground it killed it. I found a used computer for $40.00. So that's where I'm at. Thanks for the help.
    22,214
    12,851
    If that does not do it .. try changing the ignition control module May have damaged it.
    Be sure to put plenty of silicone under it.
  7. ranger1958
    Aug 11, 2011
    21
    module problems.
    I made a trip to the salvage today and picked up a used computer for $40.00.
    I was sure that was the problem, installed it and same symptoms. I had an extra distributor laying around and tried it. Fired right up and ran great! So this got my curiosity up, so I swapped out the modules. Still ran fine,come to find out it was the pick up coil. Had burn marks all on the inside. Anyway thanks to all who offered suggestions.
  8. dirtrider73068
    dirtrider73068 Moderator
    6,240
    3,680
    How was it running at all with the pick up coil bad? Good thing you got it fixed, if you had to change the pick up coil the distributor has to come out, remove the gear, shaft slides out and the pick coil can be removed.
  9. chevychase
    22,214
    12,851
    Glad you have it fixed ... and posting the fix for others to read.
  10. ranger1958
    Aug 11, 2011
    21
    it ran like the timing was moving all around, lots of popping in the exhaust. It would die alot and run really rough, hard starting.No power.
