losing coolant :(
Discussion in 'Chevy Truck Forum' started by keithr0005005, Jan 14, 2008.
  1. keithr0005005
    keithr0005005 Senior Member
    Jan 9, 2008
    156
    15
    alright well im loosing coolant...a lot of it and i cant find where its going haha. i can smell it but i cant find a drop to save my life. i dont think its a bad headgasket because my oil is clean as a whistle. any ideas? Its a 98 with a vortec 350...oh ya and for those that were helping me out this passed week with my other problem it was a defective fuel pump so the truck is running great now! thanks for all your help
  2. ryeja
    ryeja Senior Member
    Apr 9, 2007
    77
    How much is alot? Could be intake manifold gasket. Does the exhaust smell sweet and look abnormally white? Could try a pressure test of the cooling system and rad cap as well.
  3. bjf1280
    bjf1280 Full Member
    Nov 6, 2007
    24
    same truck same problems
    It seems like you and I bought the same truck. I'm glad I could help with the fuel pump, it took a while figure it out. My 1998 5.7 is losing anti freeze as well, If you find your leak let me know because I'm ready to torch my truck.
  4. 03chevy
    03chevy Senior Member
    Dec 28, 2006
    1,244
    50
    factory warehouseman
    jax,fl
    most of your gm truck lose coolant/antifreeze through your intake buy the firewall mainly on the passager side. but you have to replace both. it helps to change the antifreeze to green. flushout the dexcool that is your real problem it eats the gaskets it not made for regular gaskets.
  5. keithr0005005
    Jan 9, 2008
    156
    15
    i lose like a half gallon a week! and yes the exhaust is kind of white but i wouldnt quite call it excessive...its kind of hard to tell because it is cold out and generally in the winter you can see your exhaust fumes.
  6. fbhart@wk.net
    fbhart@wk.net Senior Member
    Mar 25, 2007
    139
    my 2000 old style chevy 3/4 ton with 350 was losing coolant, it was the valve cover gaskets. had to be replaced
    was told later by a man that worked with gm that the problem started when they changed to the orange coolant.
    however gm made a millions changing out the gaskets, mine was a $400 dollar job. He said to drain and flush system and put the old stuff back in and problem would be sloved.
  7. fbhart@wk.net
    Mar 25, 2007
    139
    sorry about my last reply, not valve cover gasket leaking coolant (dumb) intake manifold gasket leaking coolant.
    Sorry about that!!
  8. bjf1280
    bjf1280 Full Member
    Nov 6, 2007
    24
    intake
    I was just told my problem is the intake manifold gasket as well, is 400 the going price for my 1998 Z71 5.7?
  9. jimbo543
    jimbo543 Senior Member
    Sep 5, 2007
    208
    14
    GM/MOPAR certified tech
    MN
    check your block heater also, very common to leak
  10. gerryl98
    gerryl98 Full Member
    Mar 7, 2005
    Where is this located?
