motor mounts
Discussion in 'Dodge Truck Forum' started by mike hutchison, Sep 15, 2016.
  1. mike hutchison
    Aug 11, 2016
    hi all; this may seem to be a stupid question but can any body tell me what you call the metal part of the motor to rubber mount is called on a 75dodge pick up. you know the part that bolts to the block with 3 or 4 3/8 bolts then you put on the rubber mount with 1 nut or like some 2 nuts. any info is appieceated thanks to all; mike
    MrMarty51 likes this.
    6,925
    4,442
    Motor mount?
  3. mike hutchison
    Aug 11, 2016
    hey dirtrider73068; when I look up motor mounts all they show is the rubber part. I am going to put a 88 Chrysler 318 in a 55 dodge that has whats left of the 270 poly. I think the truck engine mounts will make it easier to build new motor to frame setup
  4. gmctrucks
    9,141
    4,880
    Yes there motor mounts just last weekend on some Saturday show they needed some special type of motor mounts and they found them I say this all the time Google is my friend search on it you might get lucky another thing on that show they were getting a ton of parts from RockAuto.com buzz them you might get lucky.
    Good luck! GMC
  5. MrMarty51
    Hello Mike
    Check this out. I didn`t look for vehicle specific.
    Click the CLICK
  6. mike hutchison
    Aug 11, 2016
    I looked on google and found vague refferences to mounts. mostly showed 440 and small block to Dakota car mounts. I did see mounts made from angle iron and drilled to fit, and that's fine to. But I found a site that lead to another sitethat sells a kit to mount 318-360 in most cars and trucks. The name (I hope I am right) is Tinman. It is a bolt to motor and weld tabs to frame. Its a little pricey $187.00, but could save a lot of time in fab time. I will go find the site in a few minutes to make sure of site name
  7. mike hutchison
    Aug 11, 2016
    Quick note name of company is tinman fabrication.com. And thanks to All for the help... mike
  8. BurbanMan
    BurbanMan Full Member
    Jul 22, 2014
    1,230
    990
    Stove tech @ true value
    Cortez, CO
    I've always know them as the engine perch. Your best bet is a salvage yard for finding them. I've never found them listed in the parts stores. Books or computer
