My truck keeps blowing the ignition fuse!!
Discussion in 'GMC Truck Forum' started by muddywatergurl, Jun 12, 2011.
  1. muddywatergurl
    muddywatergurl New Member
    Jun 12, 2011
    1990 GMC K1500 keeps blowing the ignition fuse. Sometimes it will try to start and sometimes it will blow before the truck even turns over. HELP!!!
  2. hugesmichael
    hugesmichael Member
    May 22, 2011
    check your wiring at the injectors with ohm meter put one probe in the white or red lead and the other to ground if it shows continuity you have a short from their to fuse block check harness for rub through.
  3. kirbymurphy
    kirbymurphy Senior Member
    Dec 26, 2009
    76
    Any after-market items you may have piggybacked onto the fuse line? Radio, alarm, amp?
