Need Help ASAP with 85 C10 wiring problem's
Discussion in 'Chevy Truck Forum' started by chevyracer8262, Sep 29, 2008.
  1. chevyracer8262
    chevyracer8262 Senior Member
    Jul 23, 2008
    144
    I have an 85 Chevy c10 that i'm having some sever issues with. I had eveything working good until yesterday morning and then all of a sudden the fuel gauge pegged out way on the other side of full and all of a sudden the blinkers quit working does anyone have any ideas on what could be the causing these problems?
  2. cburcham73
    cburcham73 Senior Member
    Aug 22, 2008
    305
    check the printed circuit board on the back of the guage cluster for breaks or burn marks.. also check your grounds. you could have have lost a ground somewhere. does your blinker light stay on when your turn signal in activated?
  3. chevyracer8262
    Jul 23, 2008
    144
    No they don't work at all. Everything worked fine untill I went to pulling fuses yesterday checking for blown fuses from other issues after that everything went crazy. I've tried different flasher fuses and still nothing.
  4. cburcham73
    Aug 22, 2008
    305
    if you have never taken the guage cluster at,then your problem might be at the fuse block .check all your fuses,wires etc. you might have wiggled something loose.
  5. chevyracer8262
    Jul 23, 2008
    144
    Well i checked all of the connections and wires as best I could last night there's power at the fuse panel and power at the steering column connectors so i don't know what could be causing this.
  6. RoadHammerTLM
    RoadHammerTLM Senior Member
    Sep 2, 2008
    301
    I had a simalar problem form my 78 C-10. And I had to pull all the connections apart and clean them. Both the front and rear of each plug ( head light switch, heater, wipers, and any other dash connection I found) and by doing this and using a jumper wire to see if I could get juice thru or around a switch they all came on. And to date still operate correctly.
    Hammer
  7. chevyracer8262
    Jul 23, 2008
    144
    Thank's I'll give that a try.
