Noise in reverse and clunk while acceleration
Discussion in 'Chevy Truck Forum' started by uslmra, Mar 5, 2010.
Tags:
  1. uslmra
    uslmra New Member
    Mar 5, 2010
    95 c1500 short bed single cab 305. 130,000 miles
    There is a loud squeak that is not constant but squeak.squeak.squeak about 3 times per turn of rear wheels cannot figure out where it’s coming from or what it is. It started out only doing it in reverse but wouldnt do it while rolling backward in neutral or forward. Now it is slowly starting to do it while going forward. I have checked all breaks and deferential fluid and greased the drive shaft U-joints. My exhaust is loud so I can’t figure out the exact location of the noise. Any ideas? Could it have anything to do with the transmission? Is it possible to grease the axel? Iv ran out of ideas
    Now that i greased U-joints i had to take the rear end of the drive shaft to get to the grease nipples and ever since then the truck now jumps and makes a clunk right before i accelerate.
    Thanks for any help!
  2. davbell22602
    winchester, va
    welcome to the forum. could be something in the front suspension for clunking noise.
  3. uslmra
    uslmra New Member
    Mar 5, 2010
    it started right after working on the drive shaft joints so might have been my fault?
    Also when i greased the u joints the rear one was a little rusty and bone dry so i loaded it up with grease and still makes noise!
  4. BernieB
    BernieB Full Member
    Jul 11, 2009
    3,880
    37
    Replace that U-joint. If it was rusty and dry the bearings in it are shot and all the grease did was allow it to slop around easier.
  5. oneluckypops
    oneluckypops Senior Member
    Feb 9, 2010
    841
    21
    Central Missouri
    yeppers yeppers
  6. 436'd skylark
    436'd skylark Senior Member
    1,143
    Mac Tool Distributor
    Pennsyltucky
    That type of squeaking is a u-joint..
  7. ChevMan92
    ChevMan92 Senior Member
    Jan 20, 2010
    155
    hopefully hot rod restoration in a week
    Devils Lake
    yeah def. a u-joint. mine did the same thing. replaced them and no more squeak
