Oil Leak - 94 k1500 350 cu. in
Discussion in 'GMC Truck Forum' started by mwoodster5, Jun 2, 2010.
  1. mwoodster5
    mwoodster5 Senior Member
    May 12, 2010
    55
    Davenport
    Im a little new to this forum but ill try and get acquainted here.
    I have a 94 gmc 1500 that i recently purchased and it leaks oil. I found the source of the problem from the lower oil cool line but am wondering somethings in relation to that fix.
    The pictures explain progress.. I have the top line removed and the filter adapter unbolted and almost ready for removal. I unbolted the lower end of the strut brace on engine/trans to allow more playing room, however not enough. I see that i must lower the front drive shaft to do so. I am wondering if i need to re-grease the u-joint in the flange after removal and once i install.
    Underneath view fliter unbolted with front end shaft in way.. DO I RE-GREASE?
    The other thing i was wondering is which gaskets/o-rings go where? i realized the odd shaped one is for the egr valve, but what about the rest? I know the oil cooler lines i bought came with their o-rings and plastic clip ins but not sure bout rest. if i even need them.
    Also here is a picture of the new lines i purchased and the good stuff Castrol GTX lol..
    Appreciate any help that can be given! Thanks
  2. oneluckypops
    oneluckypops Senior Member
    Feb 9, 2010
    841
    21
    Central Missouri
    greasing it wont hurt anything.
  3. mwoodster5
    May 12, 2010
    55
    Davenport
    Okay, but more importantly do i have to re-grease? And what about the o-rings and gaskets..which ones are used for where? should i just size compare them?
  4. crabtruck
    Welcome to the forum mwoodster5.
    Just finished that job on that truck.
    Use the hard gasket 2nd row left with three round circles.
    My eyes are telling me the 3rd (right) is also needed.
    The orange gasket from bottom row looks like original style, but too small ?
    black tube style from bottom row looks like dealer kit gasket.
    obvious easy fit for right size. Both go on top of filter adapter.
    Do not need to "drop" shaft. Unbolt u-joint and slide to left, plenty room.
    you will need to compress backwards in it's sleeve about 1"
    regrease the fitting after with grease gun on zerk.
    But all that is only if you want to drop adapter.
    Both lines can be released and replaced without touching anything else.
    Except for easier access to line clamp, remove the lower air "skid" plate.
    I needed to replace the adapter gaskets so went all the way in.
    There are some pics in my thread and I have plenty other available.
    http://www.truckforum.org/forums/ch...ving-oil-filter-adapter-1994-k1500-5-7-a.html
    Also good reading:
    http://www.truckforum.org/forums/chevy-truck-forum/24827-92-k1500-oil-cooler-connector-question.html
    http://www.truckforum.org/forums/chevy-truck-forum/22629-oil-cooler-lines.html
    I also like these pics, just me. :)
    http://www.truckforum.org/forums/chevy-truck-forum/23243-oil-leak-1991-k1500-5-7l.html#post162803
    Case 7230 likes this.
  5. mwoodster5
    May 12, 2010
    55
    Davenport
    So that info was very usefull So far i was able to do everything needed for that job. Here are some pictures of everything hooked up and what not. Thanks for the help i will for sure be needing more of it!
    Here is the filter adapter all cleaned, o-ringed and gasketed up.
    Underneath cleaned up a little
    Concerning the u-joint on the front end... i cant seem to find the grease zerk.. Anyone kno exactly where it is on the flange?
  6. crabtruck
    Right where you squeezed the grease out by compression.
    :) Whoops, think the arrow points the other way. :D
  7. RLTW375
    RLTW375 New Member
    Nov 21, 2010
    Ok I'm new here also, I have the same problem on my 94. But I don't have the cooler lines, weird, anyway WHERE DID YOU GET THOSE GASKETS!!!!! I have been looking for a week now and am about to pull my hair out. I don't want to take the adapter off and have a truck thats not drivable. I do on the other hand have a small body lift I believe and that takes away the front axle problem. (I just bought the truck) Sorry I couldn't help, just looking for a little help myself! Thanks
  8. crabtruck
    Welcome to the forum rltw375.
    The two gaskets in kit from dealer for sealing the adapter to block should cost around $8.
    See the links in post #4 above for links to more info on this project, easier than some think.
    You may be the victim of a prior owners thinking, many just remove cooler lines and then
    plug lines from adapter when they leak. Not a good idea in my opinion to abandon cooler.
    Probably could get away with it if light driving in mild temp city, otherwise fix it.
    Dropping the "skid plate" in front (4 bolts) makes easy access to cooler pipe clamp,
    and routing hose ends to cooler/rad.
    Removing u-joint clamps (4 bolts) gives extra room for pipes to get in since they
    have several bends to align along route. Your lift may save you that, but I'm sure
    you'll see pretty fast when trying to reach in there. No need to remove shaft,
    just move end a little out of way.
    I removed the end of brace strut to trans, but may be able to get around if not.
    Let us know where you find your gaskets.
  9. Oldmech
    Oldmech Full Member
    Jan 12, 2010
    1,762
    214
    Iowa
    Nice job Crab :)
  10. RLTW375
    RLTW375 New Member
    Nov 21, 2010
    Thanks crab, I have a 2500 light duty (weird I know) which has no oil cooler lines or cooler. So I'll contact the dealer today.
