Oil pan removal on 04 silverado
Discussion in 'Chevy Truck Forum' started by Mike n, Feb 6, 2012.
  1. Mike n
    Mike n Full Member
    Feb 4, 2012
    21
    Contractor
    Julian ca
    I'm in the process of trying to remove the oil pan on my 04 Chevy 4.8 l and don't know if it's easier to remove power steering stuff or remove motor mounts and jack up engine to get the clearance to remove pan?? Any body know what the best way to do this?
  2. MikeG
    2,318
    1,378
    Richland, Wa
    I don't know what the best/ proper way is; I've always jacked the motor and proped at the mounts with pieces of 2x4. I've never had any issues doing it this way.
    22,214
    12,851
    Do you have enough room at bell housing and body to jack up?
    You will probably have to pull up on motor..where are you going to jack from?
    Also on older let say 87 to 98 could get pan off without taking mounts loose or ******* up .
    Does yours have the rivets in oil pan?
    I have the step by step gm,s way to do it ..about 6 hours of work if you want it.
    22,214
    12,851
    Why in the world would it delete j a c k i n g?
  5. Mike n
    Mike n Full Member
    Feb 4, 2012
    21
    Contractor
    Julian ca
    I got the pan off and yes the gasket is riveted to the pan, if you could direct me to where I can get the step by step instructions I would really appreciate it. Thanks
    22,214
    12,851
  7. Mike n
    Mike n Full Member
    Feb 4, 2012
    21
    Contractor
    Julian ca
    Mucho gracias
  8. MikeG
    2,318
    1,378
    Richland, Wa
    Better watch that potty mouth cc! :rofl:
  9. chevychase
    22,214
    12,851
    Well i never ...never crossed my pea brain. I get it now....little slow..............................................................................
